Good news. Changing the ring & pinion gear eliminated my above 68 mph vibration. I will say correcting this issue is 100% due to the diligence of the assistant service manager at the dealership. GM Custom Care was of no assistance.
Edited by goodbye-gm
How bad was your vibration? I have a slight vibration at 70mph in the steering wheel and just wanted to see if that's what you had going on
First post, ended up here hunting down a solution to the 70-80 mph shimmy my truck has intermittently. Truck is a SCSB Z71 4x4, 5.3 with the 3.42 gears, love the truck... hate the shake since i drive everyday on the interstate and i have to be doing 69 or less or 80 and above to keep my coffee from shaking out of the center console.
After 5 weeks straight in the shop for the 45-55 mph steering wheel shake GM engineers tell them to rotate tires which still shows vibration coming from rear end. Head mechanic wanted to order a new rear end 3 weeks ago but GM seems content to push me to the boiling point. Somebody is going to pay for this BS and it's not going to be me.
this is about average for most people but for some its not this bad
GM's official position on it is that the truck is working as designed and trucks are supposed to ride like that and its perfectly normal
How bad was your vibration? I have a slight vibration at 70 mph in the steering wheel and just wanted to see if that's what you had going on
The vibration on my vehicle was severe enough that the rear wheels felt like they were hopping at 75 MPH.
This is about average for most people but for some its not this bad.
Your video is exactly like the condition my truck had. I used a phone app that records vibration to show the dealer. I would insist on checking the ring & pinion gears (backlash out of spec). That was the solution after tires (replaced Goodyear with Continental), wheels, shocks, and balanced drive shaft.
On another note, GM Customer Care was unresponsive/unhelpful until I filed a BBB Lemon Law claim.
Great video series keakar. Glad to see more vibration complaints finally making their way over to the NHSTA office of defects complaints. Keep up the good fight guys.
Service department has been pretty good so far at my dealership. They got me an appointment for this coming Monday.
It took about 6 business days to get the rear axle assembly in, which im assuming includes defferential/ring&pinion/etc.
I will report back sometime next week on my findings.
Again, my truck shakes mildly between 25-30, steering wheel vibrates at 50-55 (especially when slowing down from freeway speeds), has a "pulsing vibration" that I feel in the gas pedal between 65-70 (feels like 1 second on, 1 second off small rumble strips), then has a back and forth shake once I get to 79-80, which is just like the video posted a few posts above.
Hope this axle resolves all these problems.
I had a complete axle replaced in mine and didn't change a thing... I think my truck was the 2nd to have an axle replaced here on the forum with no fix.. Maybe I received a 2nd defective one from the same batch of axles? Good luck my friend. Trust me I went through it all and my fix was trade in assistance from GM and a truck that was built 9 months later
I was just told by my gm deal ship the vibration is coming from the prop shaft ring and pinion. They can replace it the only question is how long till it starts again. I asked about tires they laughed and said that's what other dealerships tell people. They said there will be a fix in time but for now call gm and complain. The shaft is junk they can replace it 100 times and it'll still go out. They showed me a 2015 with 300 miles that's been sitting there for a month waiting for the right parts. Guess ill just call and tell them my vin and see if they ever fix it.
2500 miles in; 4.3L 4WD Sierra dbl cab. Now getting vibration for the first time, but it's different than what many of you are witnessing -- I'm having a really harsh rumble occur at 50 mph when the truck goes into AFM/four-cylinder mode. Truck did not used to do this when switching between 6 and 4 cylinders before; there was some change in resonance, yes, but not to the point of discomfort. Wondering if an engine mount might have gone? Anyone have anything similar?
I am waiting for a new GM truck commercial stating that "unlike the competition,whose trucks ride smooth, GM trucks vibrate, which is something a properly designed truck should do". What are the odds of seeing something like this on TV any time soon?
Edited by pm26
Mine has the vibration. I know there is no fix. Should I at least log a ticket with my dealership even though I know they can't fix it?
My 2015 2500 Denali HD has a bad vibration also Dealer tried to fix even went as far as to putting a new set of Michelin on ,did not help.Went to several dealerships and drove 2015 2500,s all have same problem had a 2007 2500hd Denali no vibration Truck sucks only problem is I been driving GM products since 71. also headlights are horrible can't see anything at night very unsafe any suggestion
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
