Too bad GM is not buying back THEIR screwups. I guess they'll wait until the Gubmint orders them too also. Plus we're talking about older Rams vs current GM's. I don't care which company it is. I think they all dropped the ball with all this outsourcing and foreign plants. Everyone must make their own decision based on their own situation. If your vehicle has problems and the manufacturer refuses to do the right thing, then move on. It's not worth the hassle anymore. If you actually find a good truck whatever brand, then keep it and count your blessings. The days of brand loyalty are over because the manufacturers no longer have loyalty to their customers.
So true and you've pretty much nailed it on all accounts !
A guy at work told me of a lemonlaw lawyer here in michigan who used to work for the big 3 and got his car bought back in the late 90s. Im going to call on monday and get something started and drop it off for the second attempt asap.
GM doesn't call back and what I was told was that district sales manager has final say on buy back....doesn't make sense.
Sent from my iPhone
You are gambling on whether GM will actually issue a recall to fix the issue. Otherwise you could see the resell value plummet once word spreads like wildfire throughout the automotive industry.
I highly doubt they will make a recall unless forced, that would mean admitting that they did something wrong, They won't do it, just like FIAT/Chrysler wouldn't make the replacement parts to fix their issues
Every truck would have a vib then. There are hundreds of thousands that do not or there would be many more of is here. It could even be shitty wheel bearings allowing the wheels to wobble. My dealers been replacing quite a few rear wheel bearings.
I correct myself, its tires, drive shafts, rear ends, AFM, and all of the above and in any combination...
My truck definitely has bad AFM, got the standard "nature of the beast, how the truck is response", I have a feeling that the tires could use a roadforce test & rebalancing/ replacement but they won't do anything because even though they admitted there is vibe, they claim its all drivetrain. so I'm keeping all my options open for potential issues.
It just gets worse and worse dealing with these people haha.....thanks for the heads up!
everything comes down to bottom line, they don't really give a shit about us.
Sent from my iPhone
that doesnt sound good for me, the regional rep already said "normal operation", what a bunch of scumbags
LAWSUIT UPDATE:
lawyers have not called/ emailed me back
GM just authorized 4 new tires and new rear shocks based on the feedback from the vibration meter for my 2014 6.2 High Country. It will be interesting when I pick it up this week.
The motive gear set is for the older 9.5 rear end which has the 14 bolt cover. The k2xx has a 12 bolt cover and uses a different gear set. The AAM gear set is the same ring and pinion that GM uses. The entire rear axle is built by AAM for GM. In order to use the the gear sets for the old 9.5 it requires adapters, new bearings and a diff cover space to clear the differential. This rear end has been out for 2 years now and no aftermarket manufacture has cut gear sets for it. The only gears that fit without adapting are the AAM's which are what are in there to begin with.
So, this is very very interesting. Did some research and found a couple of interesting things:
1. AAM is interestingly ex-GM. When GM went out of the driveline business, they were going to close a bunch of plants. Some ex employees bought 5 of these plants and started AAM.
2. AAM's website has some very interesting info. They talk about their 2 cut gears. I found some information on what that means. Older technology was what they call 5 cut machining process. The new 2 cut process eliminates 3 steps where they cut each gear in one step. So, less steps means less cost. But, supposed to result in more accurate, quieter gears. Backlash setups are different. Now, it wasn't possible to make 2 cut gears years ago, but supposedly modern, precision machine centers have allowed 2 cut process to be done now.
So, makes one wonder. It all sounds good on paper, but like most new, high tech processes....things can go awry. Would not surprise me if AAM have messed up something with this new process, and of course since they are the sole supplier (supposedly), no surprise that many of the replacement attempts ended up with the same vibration. If this is what's going on, GM has a mess on their hands. First, they need to get the problem sorted with AAM. Then, are they actually going to replace all the gear sets in every vehicle? Definitely not. They will only replace the ones they have to. Customers that demand it.
And, this is not a safety issue, so don't expect a recall. TSB at best.
And, the new process requires lapping of the gears. Hmmm. That sounds like a step to get missed or not done properly!
Of course, it would be interesting to know when the industry in general went to 2 cut gearing. And, is the 2014 pickups/2015 SUVs the first generation that GM went to 2 cut gears? Interesting.
Well, removed my Range AFM disabler and guess what? The vibration was ridculous! I'm gonna try and get a video of it today to show my dealer. Gonna do the "water bottle test". I also get a vibration with it in v8 mode around 73+ mph. Steering wheel shake (up and down), passenger seat back shakes, you can feel it in the seat. Crazy. Love the truck but damn not sure if I can live with it.
Anyone know if the 2500's also get a vibration?
Yes, the 2500's and 3500's have the same issue. Go to the HD forum on this website and there is an active thread there.
they authorized a new complete rear end for mine. including rotors calipers everything. hope this takes care of the issue on mine.
Posted last week that I've started to notice the vibration more and more. My buddy even mentioned something while rolling down the highway this weekend without me saying anything. Now I gotta make time to go take a tech on a test drive.
Is it bad that I've already started looking at replacement trucks for this thing? Lol
New rear end for my first 14 didn't solve it... Good luck
I feel for you guys that can't get the 70mph vibrations removed. I was lucky enough that mine went away after getting my tires road-force balanced. I still have a 25-30mph vibration but its random.
Well folks, I did it. After all the failed attempts at the Chevy dealer I traded it in for a 2015 Ram 1500 Larame. I have to agree with the other folks on here that have done the same thing, it was the best decision I made and I am very happy. I will admit, it's disappointing though, this is my first non-GM car in close to 20 years. They really screwed the pooch on this one and lost a long time customer. Too bad they really don't care. Well, I am off to a nice, smooth vibrationless drive to the camp ground. I wish you all the best of luck and will remain subscribed to the thread. I am interested in the outcome.
  • Like 9
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
