A few observations about my truck's vibrations:
  • They seem to be worse with higher psi in my 10 ply tires.
  • Once they get going at high speeds, it is hard to get them to stop and it feels like it is going to vibrate me off the highway.
  • I've tried with the rear leaf spring clamps, can't say definitively whether it has helped.
  • Anything messing with the suspension in the rear temporarily helps it. For exam, I have the Firestone Ride Rite air bags in the back. If I inflate them and raise the back of the truck, it rides without vibrations for several miles, but then they come back. If I let the air out and lower it back down, I have the same thing - no vibrations for a while and they they come back.
  • They seem to be less severe in turns.
  • Most of the time they are better if I keep it in M5 and tow mode, although they are still there. I can't figure out if the engine is unbalanced at low RPM's, or if the higher RPM's at a given speed are helping to counteract or balance out the harmonic vibrations.
  • I've owned several GM trucks before. My last one had 200k+ miles and drove much better than this one drives now. I was aware of the vibrations in 2014's before buying my 2015, and test drove it extensively on the highway. It was smooth as glass for the first 1500 miles.
The dealers have been pretty much worthless. I can't get them to return my calls, and when I drop it off they do almost nothing except drive it and say it is operating as normal. The last dealer said it definitely had the vibrations, but that they aren't getting enough money from GM to make it worth their while to work on these trucks. They have had several of them with no resolution. On the service write up, he blamed it on my aftermarket tires and leveling kit, even though I clearly brought it in with the same problems prior to new tires and leveling kit.
This problem, and GM's lack of acknowledging it, are causing me to consider other brands for the first time. I have been very GM-loyal customer but this is all changing. My wife was in the market for a Yukon Denali but is now looking at Infiniti's, Toyota's, etc. I'm now looking at F-150's if I can't get the ride problem resolved.
Edited by gmtruck828
Did the same thing, lowered the pressure on my 10 ply tires from 42 to 32 and significantly lowered the vibrations as well. Problem is the truck now handles like garbage leans in the turns and just has a squishy feel to it.
Anyone else that has had the vibes for a while check the lower portion where the struts welds to the mounting eye that connects to the lower control arm. Mine are starting to crack. They are not the original Rancho's that came on the truck but 6 month old Rancho RS9000's, I contacted Rancho to see if they will warrant them. Just curious if anyone else with the vibes is seeing cracks in this location on the factory struts. Part of it is poor weld quality where there was a void left from the weld process that has helped facilitate the crack propagation. Rancho's "lifetime warranty" doesn't include their quicklift struts they are covered by a laughable 90 day limited for work and material defects. But I'm giving them a chance to stand behind their product. These things only have 8000 miles on them. We shall see how they handle it.
I have about 6500 miles, ill check mine
I am a GM employee and having the same problem with my truck. I have been in touch with district manager and spoke to the engineers directly and no cure has been found. The problem is the new designed frame multiplies the vibration and shakes the truck. The picoscobe puts hose clamps on he drive shaft in a attempt to calm the vibration with no luck.
Gm offered a buy back but they have nothing to offer that fits my needs and don't want to trade to another vibrator. I have a 2015 work truck regular cab short bed plow and tow package that I can not drive over 70mph year long and with the plow on you can not drive over 40mph ( a complete other problem gm has with out a cure)
I'm waiting for Prothane or another aftermarket company to come up with a new mount. What I don't get is why they don't have one for the 14-15's yet... seems like they would already have one??? Maybe they're having a hard time developing one. I'll admit, I keep trying to remember to do it, but I have yet to actually look under my truck yet at the mounts, etc.
I've been thinking the frame has been too stiff and resonance since the beginning. They kept pushing the envelope on frame stiffness (watch youtube videos of Silverado VS whatever frame stiffness) and the Silverado box barely moves on that tilted hill thing and all the other trucks twist. It's also evident with the firmer ride. My 00 Z71 on crappy roads (most of what's around here) rode better (softer) than my new truck.
http://www.prothanesuspensionparts.com/?gclid=CJOrloSC_8kCFdgWgQod_PYGiQ
I love this damn truck. Whether GM fixes it, or the aftermarket does, the damn thing is going to be fixed! Stuff gets lost in the mix, but I do not have the crazy highway vibes everyone else does... mine are felt during shifts and going up hills in certain gears (like the engine lugs a bit). I've also noticed my wifes 2011 Mustang does the same thing, it tries to keep a higher gear too long up a hill and the floor will have a slight buzzing vibration until you get over the hill or the car actually downshifts. Also noticed it recently in my inlaws 2013 Rav-4. I guess this truck made me more concerned with vibrations and I notice them in everything I ride/drive now. I don't think all these issues are a "GM thing", because some of these issues seem to be across the board, but I do find those having the highway problems inexcusable, I've seen the youtube videos.
Edited by 67ChevyRedneck
I know I had energy suspension polyurethane body mounts on my 02 and it made the ride so much worse I can't imagine what it would feel like on these fully boxed stiff frames
Well, damn it.
My 67 C10 has regular old rubber hockey puck mounts. I wonder if I can cut or shim a set to fit on my truck.
Be a guinea pig for all of us and get the body mounts for the gmt900 trucks and let us know if that kills the vibration lol
Seriously thought about it, there's plenty in the local LKQs. If it works I can buy new ones. I have to get under the truck to see what's there now to compare, but yes, seriously thought about that. They can't be that different, aside from the stiffer materials the new ones are supposedly made from now (from what I've read in this thread). Rubber can be trimmed or they can be shimmed with larger washers, so I don't see why it wouldn't technically work...
Like I said though, my issue is nowhere near like everyone elses. If all else fails, I can actually "live with" what's wrong with mine. Probably never buy another brand new truck again (from anyone, this was my first and probably last).
If you do it you will be everyone Savior to know if it will work or not and if it is the body mounts or not. Be a hero and do it for all of us lol
Looks like the 2015 f150 guys are having some of the same problems.http://www.f150forum.com/f118/2015-f150-fx4-vibration-help-297498/index8/
Yeah I believe we have discussed this earlier but it's not near as widespread (yet) or as common as the GM twins. My buddy has a 2015 with a 2.7 EB with no vibes, he said during his research it was mainly the 5.0L owners that had it, but I don't have any facts to back that up so no bashing the moderator here lol
It seems to be like the GM issue then... hit or miss. My boss has a fully loaded 2015 King Ranch 4x4 edition truck. He uses it to travel for work, so it already has like 12K miles on it. I rode in it recently on a +/-500 mile round trip to TN and back, was one of the best riding trucks I've been in.
Edit: To comment to post above, this truck was the V6 ecoboost.
If it was smooth as glass for the first 1500 miles, perhaps GM should revise their warranties accordingly - 90 days or 1500 miles, which ever comes first. This will be in line with harborfreight electric and pneumatic tool warranty policy, which is reflective of the quality built into the product.
Edited by pm26
I need to try this...mine were at 40psi from dealer...just dropped it to 32psi and now looking forward to my drive to work in the morning.
I'll let you know !
Dropped the PSI down to 32 all around...going to work the vibration was only at 72-74mph...not at 65-70.
Unfortunately going home the same thing now at 68-74mph.
The truck rides beautiful up to 60mph...what a hunk of expensive crap, I really don't have the time to hang out in the dealer having them tell me it's normal...I build motors and do classic car restorations...I know frigging normal...and this ain't it.
Edited by Radco2015
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
