I haven't experienced this issue but I had the TSB fix done a while ago.
A friend experienced this on his 2016 Sierra and I mentioned the TSB. Dealer didn't even know about it, same as my Chevy dealer when I wanted it done prior to any potential issues.
Everything was good for my friend after the TSB fix.
https://www.tsbsearch.com/Chevrolet/21-NA-199
MC-10207911-9999.pdf
Edited by MikeBMW
  • Thanks 1
On 1/2/2023 at 7:53 AM, Snoringbear said:
Thanks for this!  The GMC dealership that I took my truck to knew about the Thermal Bypass Valve and the shudder.  I had them replace the TBV as well as flush the transmission.  This took care of the dreaded Silverado Shutter.  Total cost was $1,037.  I asked how often the tranny will need to be flushed, they told me every 60,000 miles.  Granted I won’t need the TBV changed again, but that’s still $800+.
There was a TSB that came out around 2016 ~ 2017 for the tranny flush and replacement with Mobil 1 Blue Strip I think it was.  I had it done for tranny shudder problem which it fixed.  It also reduced but did not eliminate low speed hard shift problem between 1st and 2nd.  For some, torque converter replacement was necessary to eliminate shudder.  About vibration problems; I not aware of any single fix for that.  If you read back through the hundreds of posts you find the root cause blamed on virtually every part on the truck.  I don’t think it was ever eliminated from this generation truck which is 2014 ~ 2020 or thereabouts.
On 1/9/2023 at 6:37 PM, steelerdude15 said:
Is the vibration occurring when you’re accelerating or braking? If it only happens when you’re braking then the rotors are warped and need replaced. If it’s doing it while accelerating, it’s something else.
Never when braking or coasting. Only under power.
On 1/15/2023 at 1:16 PM, Richard Carrillo said:
Well, mine made it about 45k. I don't recall having the TBV valve replaced, but I'm calling service department back tomorrow. Guy was very helpful when I called him last week with pulling up my service record and notes.  Appreciate you updating the post.!
  • Thanks 1
3 hours ago, Richard Carrillo said:
I would highly recommend getting the Thermal Bypass Valve replaced. .
OK. Looking up that part on GM Parts. Also looking at some service videos. Doesn't look too daunting to do in an afternoon. Might as well change the filter while I'm there. Probably best to have a seal on hand even though the OEM is reusable just in case it gets damaged. The fluid is crazy expensive.
 https://www.gmpartsonline.net/oem-parts/gm-valve-86774933
https://www.gmpartsonline.net/oem-parts/gm-automatic-transmission-fluid-filter-kit-with-seal-24236933
https://www.gmpartsonline.net/oem-parts/gm-automatic-transmission-fluid-pan-gasket-24260071?c=bT0x
Last May, we got a (new to us) 2017 Silverado with the 6.2L 6 SPEED auto. It had 33K miles on it. After we towed our RV on a couple of camping trips, I noticed it was doing that 'vibration' or 'shudder' thing. I got progressively worse and sometimes the shifting would be jerky in low gears in a down shift or upshift 1 to 2  or 2 to 1 shift.
Then it would, say around 45 mph, shudder that felt like I was going over rumble strips in the road. Yes it felt it was coming up thru the steering or tranny.
I did some research and discovered that this "Chevy Shudder" was a well-known issue that was ignored by GM. Seems that many of the trucks assembled in Mexico, the wrong type of tranny fluid was used, and Chevy just shipped 'em out anyways with no remediation.
This would cause shuddering, erratic or jerky shifting, etc and but the time it got that bad, the torque converter was shot and would have to be replaced. I called a couple of Dealers and the were welcoming me to have a look at it, for a fee, of course. I declined and called a local GM dealer and they took it in and looked at at and ended up replacing the automatic transmission - flush and fill some 20+ quarts at no charge, as it has a factory warranty until 60K miles. That, so far, has cleared up the problem, but if it comes back they'd said they'd do the torque converter replacement, as the wrong fluid glazes up everything in the TC. So might want to check that out and see if you too have "The Chevy Shudders".....
  • Thanks 1
  • 4 weeks later...
I am not the original owner, but the title was transferred with only 6,000 miles. Didn't notice any vibration or shake until around 25k miles. It was very slight and progressively got worse, it was only and issue at certain ranges of speed. Since I wasn't the owner I never received any notices even though I updated all info with GMC. The nickname I heard was The Chevy Shake. The issue, as I understood it, was GMC put the wrong transmission fluid in it. Obviously my truck had the issue but GMC said my VIN was not included in the list of problem vehicles. Dealership wanted around $700 and GMC said they'd do what they could to help. Didn't trust that at all. Friend of mine owns a auto service & repair business. He said he was familiar with the issue and, although he works exclusively on Honda, Acura, Toyota & Lexus; he said he'd do it one night after they closed. I paid for everything. He did the drain, flush, clean and fill. I live about 15 miles from his shop and by the time I was 2 miles from the house 75% of the issue was gone. Over the next day the issue was completely gone. Took a 350 mile roundtrip drive the next week and not a single issue. Had it all done for $200. Trusted my buddy more than the dealership.
  • Like 3
12 hours ago, MikeBMW said:
Did you get the updated thermal bypass valve, as well?
Yes
I just paid a local shop to do this, what are the odds I can get a refund from GM?
It's no longer supported under the TSB.
My friend had to pay about $180 (if I recall correctly) to have it done at his GMC dealer.
Included transmission fluid change, as well.
So, unfortunately, no refund, but, as I mentioned, it fixed his issues and I had it done as a preemptive measure at my Chevrolet dealer. Pretty sure I paid, as well ... I'd have to go through my receipts.
Edited by MikeBMW
It definitely fixed mine, I was hoping maybe I could get them to flush and change the fluid. Either way, thanks for the info.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
