I readjusted my seat to sit lower in the rear and the clunk has basically gone away. I don't like to sit that way but I will until I get the clamps rigged up.
Post 278 guys. This is what it looks like.
Works perfectly!!
where can I buy these clamps
Sent from my iPhone 6
using Tapatalk
Sounds like the rocking Recaro seat issue I had on my CTS-V that GM refused to fix...
That reminds me of a similar experience about 6 years ago. I got into the driver's seat of a brand new Corvette in the dealer's showroom.
The seat seemed to rock back and forth so much that I could not believe that someone would let this car out of the factory like this. Great testament to GM's nonexistent quality control.
Edited by pm26
Instead of using the expensive loops to get the rubber. I just bought a square of some for $2 and only needed a little. I think some old intertube would work also. This does look more getto, but so does house clamps on a $2000 seat. I'll still tell my dealer when I go in to log the issue.
Love the truck. Hate the drivers seat. So much so that I don't even like to drive the truck. I noticed the problem within 2 weeks of purchasing the truck. It is not only the seat movement issue, it also feels like the seat bottom upholstery has shifted around to the point that it feels lopsided. I have not contacted the dealer as yet as I am hoping that GM will come up with a fix that actually works. I read this entire thread and do not see an definitive fix that can be completed by the dealer. I want them to fix it and fix it right. No hose clamps!
Chalk up another win for the clamps fix. Bought 2x 1" hose clamps and 2x 1" rubber insulated clamps from Lowes. removed the rubber from the insulated clamps, trimmed it down to 3/4" and slid it on the hose clamp. Installed them tight up against the inside of the white clips under the seat. Problem solved. Took me longer to buy the bits inside Lowes than it did to install. Source fix, as mentioned before is on page 19
http://www.gm-trucks.com/forums/topic/154219-seat-movement-issues/page-19
Had the dealer apply the fix last week and all is well so far.
Sent from my Surface with Windows RT using Tapatalk
I had the dealer order the parts and they have an outside upholster come in to do the repair. They told me that all work like that is farmed out. Its been 3 weeks and all is well. Maybe you need to have the right trade doing the work. Something that a wrench turner may not be that good at. And he didn't remove the seat to fix it, the guy removed the seat cover to do the repair. This was explained to me, now I wish I would have asked to watch him do it. Will keep an eye on it, but so-far-so-good!! I'm happy again!!
Edited by sduff
Happy to report that my seat has been fixed. The fix explained sounds similar to the clamp fix. They drill holes in the bar and install clips in the new holes on both sides. So far so good.
Had my drivers repaired a month ago, they basically rebuilt the entire seat frame. Got it back and immediately it felt great, like a seat should feel. Rigid, zero movement or swaying. Guess what? It's back!! I can feel a slight swaying in the lower back area again when going around corners and on bends in the road. Keeping an eye on here for a permanent fix to this.. So frustrating!!!
I finally did the "hose clamp" fix this weekend. I can't believe I waited so long: it's like driving a whole different truck. Thanks for showing me how.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
