I readjusted my seat to sit lower in the rear and the clunk has basically gone away. I don't like to sit that way but I will until I get the clamps rigged up.
Post 278 guys. This is what it looks like.
Works perfectly!!
where can I buy these clamps
Sent from my iPhone 6
using Tapatalk
Sounds like the rocking Recaro seat issue I had on my CTS-V that GM refused to fix...
That reminds me of a similar experience about 6 years ago. I got into the driver's seat of a brand new Corvette in the dealer's showroom.
The seat seemed to rock back and forth so much that I could not believe that someone would let this car out of the factory like this. Great testament to GM's nonexistent quality control.
Edited by pm26
Instead of using the expensive loops to get the rubber. I just bought a square of some for $2 and only needed a little. I think some old intertube would work also. This does look more getto, but so does house clamps on a $2000 seat. I'll still tell my dealer when I go in to log the issue.
Love the truck. Hate the drivers seat. So much so that I don't even like to drive the truck. I noticed the problem within 2 weeks of purchasing the truck. It is not only the seat movement issue, it also feels like the seat bottom upholstery has shifted around to the point that it feels lopsided. I have not contacted the dealer as yet as I am hoping that GM will come up with a fix that actually works. I read this entire thread and do not see an definitive fix that can be completed by the dealer. I want them to fix it and fix it right. No hose clamps!
Chalk up another win for the clamps fix. Bought 2x 1" hose clamps and 2x 1" rubber insulated clamps from Lowes. removed the rubber from the insulated clamps, trimmed it down to 3/4" and slid it on the hose clamp. Installed them tight up against the inside of the white clips under the seat. Problem solved. Took me longer to buy the bits inside Lowes than it did to install. Source fix, as mentioned before is on page 19
http://www.gm-trucks.com/forums/topic/154219-seat-movement-issues/page-19
Had the dealer apply the fix last week and all is well so far.
Sent from my Surface with Windows RT using Tapatalk
I had the dealer order the parts and they have an outside upholster come in to do the repair. They told me that all work like that is farmed out. Its been 3 weeks and all is well. Maybe you need to have the right trade doing the work. Something that a wrench turner may not be that good at. And he didn't remove the seat to fix it, the guy removed the seat cover to do the repair. This was explained to me, now I wish I would have asked to watch him do it. Will keep an eye on it, but so-far-so-good!! I'm happy again!!
Edited by sduff
Happy to report that my seat has been fixed. The fix explained sounds similar to the clamp fix. They drill holes in the bar and install clips in the new holes on both sides. So far so good.
Had my drivers repaired a month ago, they basically rebuilt the entire seat frame. Got it back and immediately it felt great, like a seat should feel. Rigid, zero movement or swaying. Guess what? It's back!! I can feel a slight swaying in the lower back area again when going around corners and on bends in the road. Keeping an eye on here for a permanent fix to this.. So frustrating!!!
I finally did the "hose clamp" fix this weekend. I can't believe I waited so long: it's like driving a whole different truck. Thanks for showing me how.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
