Recently got my trans tuned by Black Bear... It's a huge improvement over stock! If you can only afford engine or trans tune, get the trans done!!
I'm assuming the answer is "yes". Buuuut, does a trans tune change the CVN values?
You assume correctly.
Maaaan, If this was the third year....I'd have tuned it at 300 miles....lol. Being year one....I think I want to see if any "bugs" come up.
I was the same way... And I said exactly the same thing, but I caved. The only reason I broke so early was because I kept my laptop plugged into the truck monitoring what it was doing for a couple months, then I fell off the band wagon. It was so much harder for me knowing I had the means right in my hand and it wasn't going to cost but just $100 for the two credits it takes to marry to a PCM. It's like a recovering alcoholic working as a bar tender... I was my own enabler.
Yeah, it's getting hard for me, too.
I have one of the best tuners on the Eco platform that broke the whp barrier on the stock fuel system at my back door. Letting him see what he could accomplish on this one is so freaking tempting.
Haha, I'd probably more apt to tune a leased truck depending on the length of lease.
It's a 39 month lease. But I don't know if I will end up keeping it or not at the end of the lease term. I don't want to have to return the ECM to stock. If I end up keeping it the first day after I buy it out, I will get it tuned by BlackBear.
I got a deal on my 5.3 14 Silverado but it had the 3.08 in it. I will need to tow possibly up to 7000-7500lbs sometimes so I've been trying to decide on swapping to 3.42's but the tune has been something I've been worried about after doing that. Reading this thread had made me really want to tune it and since I'm in NC PCM of NC looks like a great idea. Curious though, do you think I could get away without changing the gear's with a tune since that would adjust the transmission pressure/shift points? Or would that not really impact the towing capacity?
Thanks,
JB
Thanks,
JB
After a good tune you will think it can pull your house off the foundation, even with 3:08, and especially if they know what they are doing on the transmission and E85 side of it, hell on E85 I am pretty sure I would paddle last years 6.2 at the track and give a stock '14 6.2 a run for their money.
I would still consider swapping the gears. It would just make the towing experience more effortlessly. The gears would keep you out of the lower gears more often.
I traded in a 2013 EcoBoost F150 4x4 Off-Road w/3.55 rear.....on the 14 Silverado 4x4 with 3.42's. As far as the bottom end power to get things going quickly....the Eco won. However, my overall towing experience with my side x side and trailer at around 4,000 lbs.....had been hands down better with the 3.42's and 5.3L.
Now with a tow tune in the EB....it was pretty amazing. So a tune with the 5.3L should make it pretty awesome, too.
I would do the tune first, and if you need more.....go with the gears.
For anybody thats gotten a blackbear tune on these 2014s. How did you get your autocal to bring up e92.. The file for these 2014s to be able to tune them? Example... "Read e92" read e38... Etc. ive updated all the softwAre and it isnt showing the e92 file
You will need to load the new configuration file in the autocal. Email Justin and he will fix you up.
Thanks i already did this mornin. However i know people get busy and i thougjt i could get an answer faster on here. He sent me the e92 file i jus dont know how to put it on the autocal
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
