I have a 5.3L crew cab and the only thing I've done so far is installed flowmaster dual exhausts. I live in Baton Rouge, Louisiana and I've been emailing back and forth with a nearby performance tuning shop. After explaining to him what I'd like to see from my truck, this is what he told me after some research on his end: "We can go 2 different routes, we can get a Diablo Sport InTune $325.00+S/H or a HPTuners VCM Suite package. We can split the cost of the VCM tuner for the HPTuners and also the cost of the dyno tuning. In return I get to keep the VCM Suite from HPTuners." My question to you guys, especially the ones who've already had their trucks tuned, which route would you suggest?
Which shop are you referring to? We have two respected tuners...EPS and Futral... but that information you mention doesn't sound like either of them.
Oh I just saw your other post. Not familiar with Corr. You might try the above shops I listed. They have been in the GM stuff for a long time doing tuning. EPS is in BR and Futral is in Walker.
Thanks so much! I'll get in contact with EPS. They're minutes away from me! Corr is much further in Kenner. I appreciate everything!
There you go... this is why these forums work.
I spoke with Jeff at EPS and he said they haven't started tuning the 14's yet because of the new system. He said it'll be at least another month before they start. I'll give Futral a call and I may also try Diablew. I'm just ready to unleash her full capabilities! Thanks again!
Edited by Thaheavyone
I think Alan has done a couple. I'm waiting a while before I do anything and let them build their knowledge. Lol
Has anyone tried the Bully Dog/Computer Chip? Autozone sells it online for $399, but a nearby Autozone has it for under $300 in the store. I talked to someone who used it on his '14 Sierra and he loves it.
Be nice to ad 15-20hp, but man....that warranty looming over my head.
Sent from my DROID RAZR HD
Yeah, but HP/TQ is far from the only story. Especially for those who race, but even if you don't....things like launching from a powerbraked 2600 RPM instead of a 1/2 throttle 1500 RPM can put a smile on your face even without any increase in HP.
Booked my appointment at Futral Motor Sports for April 30th. We decided to go with a street tune 1st since I'll probably add more mods and I'll only have to pay the $150 difference when I'm ready for the dyno.
That's exactly what I keep saying.... HP/TQ is about 10% of a good tune on these trucks. You will get the most joy out of what is accomplished on tuning the transmission. You won't get any quality transmission tuning out of a canned tune either... I cant stress enough to go custom. Any guys here in the Tulsa area that have gone canned tune already, come drive my truck and see how quick your Hypertech/Bully Dog goes on Craig's list. :P
Edited by TDT
  • Like 3
This is EXACTLY what the guy at Futral told me when I asked him about Bully Dog. He explained to me how only a custom tune will unlock your truck's max potential. Those yes/no questions will only take your truck so far. That was all I needed to hear! Lol.
I wish you lived in NC, haha. It was a no brainer to tune the Eco...if I had a 6.2 it would have already been tuned....but with 5.3L I'm trying to justify the gains out-weighing the potential warranty loss down the road.
My ideal would be around 20 more whp and 30 more wtq...that is 100% safe to tow up to the 9500lbs. I can't wait to see what a set of LongTubes does to open up a stock motor and then on a tune.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
