Try to post on their forum, they seem to reply a little faster. I already got a reply on not having adjustable parameters and have sent them another file they asked for. I have worked with Mike Litsch (sp?) and he's been great.
Same here. Mike just gave me a new tune that I will install shortly
Installed the new tune Mike sent me and works perfectly.
Mine works now. I installed the ob tune as I initially had the oa tune. I actually feel a power difference as well this time which has me wondering if the tune even worked before. Had her up to 103 on the freeway last night to test if the speed limiter was still there. Now patiently awaiting TCM support...
Jenna,
I am going to install a flex fuel sensor on my 2015 6.2. Can you enable your tunes to maximize for E85?
Just installed my Black Bear tune today... 100% worth the money. truck feels like and performs like it should have out the door.
Throttle response is excellent, shifts are crisp and firm, definitely a increase in power... though i was running 87 oct on stock tune, now im running 91 oct w/ 91 tune...
I was a little apprehensive about doing everything by email... i can understand why they do this though, i imagine they would not be getting any work done with all the phone calls. They responded back at end of next day with my email questions, only took 2 days to get the tune in once i submitted the files.
Thanks Again.
Edited by CalicoJack76
To ROBVAS and WURGS, is this your first tune or was is this an updated tune? I am getting ready to bite the bullet so to speak and I am really hoping for better transmission response… I ask because ROBVAS stated “new tune”…
This is the second tune DiabloSport provided me. The tuner didn't recognize my truck (brand new 2015) out of the box, so I sent them the unknown_pcm file and they sent me a tune that worked, but I couldn't adjust anything like AFM or tire size etc.
Then they sent me a second tune and everything acts like it should.
Copy Robvas. I am actually looking at a BlackBear tune for mine. Sorry, my bad.
Thanks Again.
Thank you for the review Jason! Happy to hear you are enjoying your tune.
You are absolutely correct, the guys do everything through email for a few reasons:
-they receive hundreds of emails a day, on top of building tunes, shipping items, and inperson tunes, phone calls would put them very behind
-phone calls does not leave any documentation: they are able to go back through emails to see what a customer requested, or other discussions pertinent to the process
-they can't see what is going on through the phone: if a customer has major issues with the AutoCal process, they will remote into the computer to assess the situation. This is much quicker than trying to decipher what someone is seeing, through their explanations on the phone. More times than not, the customer has missed a step, and the guys can quickly diagnose when they log into their computer.
-phone calls rarely take 5 mins: most customers will want to continue the conversation, once they have the guys ears, not realizing the backlog of customers in email. How is that fair to the guys who have been waiting for a response via email, that someone who calls, gets to go right to the front of the line?
yep.
Just something I am not used to... others might not be as well, just wanted to post up a good review of the process
Thanks Again.
The more you drive it the better it gets and the more you will like it. I also got an Air Rait MIT intake tube and filter and if definitely helped out low-mid range torque. So if you don't have an aftermarket intake I suggest you get one.
I installed an AirAid Tube but retained the original filter box on my 14 Crew. I did not want to get into K&N or an oiled filter because I seen what they can do to the throttle body on motors. So far not much of a difference and with my Borla muffler I don't hear much additional noise from under the hood. :tear:
I am a believer in letting any engine breath a bit better... works wonders on a V twin.
Same here. Noticeable difference in power and actually just got 1.3 mpg better on my last tank driving the same routes as before. I will be curious to see if it was a fluke or if it will continue.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
