MPG after tires/lift?
Ghilie
53 minutes ago, JerryCanada said:
I have the 5.3L with 3.42 gears. 2" level kit and 275/65/18 BFG KO2's on  it. I get anywhere from 10.5 to 12 L/100km on highway and 14 to 17L/100km in the city. My opinion is that the 5.3L is worth the extra $ as a bigger engine will not work as hard to push the truck around and also being the most popular engine can be a plus in the long run.
Sounds logical but a 4.3 won't be straining with this level and tire combination.  The 4.3 has ample power for the task and the 5.3 has even more!
That is the exactly the information I was looking for.  Thank you!  Also the same tires I'm looking at.
8 hours ago, GoBlue2014LT said:
2014 4.3 L - stock I was getting 18 average which is 75% highway 25% city. After 2.5” level and LT275/70/18 I am now around 15.5 MPG total after about 1200 miles on this setup
Perfect, thank you for that real world information.  Do you ever regret not getting the 5.3, or do you have plenty of power?
4.3 has plenty of power for normal driving but for towing purposes I wish I had the 5.3 or 6.2. I bought the truck used. Next truck will be be either 6.2 or HD just so I can get a bigger camper.
On 10/31/2017 at 11:25 AM, youn1033 said:
These responses give me some concern as to whether or not there's an issue with my truck...
I've got a 2018 Denali w/ 6.2 & 8-speed. It is leveled with 33x12.5 Nitto Terra Grappler G2's as well as a Retrax ProMX rolling tonneau (thinking less drag here) + a Borla Touring GMPP exhaust. I have been REALLY babying this thing on acceleration, foot off the gas on hills, etc. & while driving my daily commute down a straight shot of I-10 w/ >90% being Highway, I STILL cannot seem to crack an average of 16mpg for at least 1/2 of a tank...
Note: I was getting essentially the same results prior to the exhaust as well.
Anyone know what might be going on?? This truck has 2,200 miles on it.
The stock tire size is 265/65/18 = 31.6" tall x 10.4" wide tire.
You have significantly larger tires + a lift. So you have drastically changed the aerodynamics of your ride. Plus your speed on the freeway makes a big difference. You lose a lot of fuel efficiency increasing your speed from 65 mph to 75 mph. The EPA tests are done at like 55, which isn't even freeway speed, but they still call it highway. I'm guessing you drive much closer to 80, which will also kill your MPG. The tonneau cover barely makes a difference, as well as the exhaust. Maybe a fraction of 1 mpg combined over stock.
16.5-18mpg being average or HWY?  Thanks for the reply.
90% highway
2014 Silverado 2WT 4.3 V6
Instagram @egroj_legnar
YouTube.com/jorge_dropkick_rangel
I agree with the aerodynamics portion and the fractional difference from the exhaust/tonneau, however everything I've read said that you're looking at 1.5-2 for just a level and 33s.
Even if that exhaust/tonneau offers nothing in return, if a truck shows to get 21hwy as "tested", and there are guys on here reporting 19-20hwy, 15.5-16 still seems pretty far off base IMO.
Also to clarify, as much as I'd love to (and otherwise would) drive (above) 80, I've been doing this test for science! I'm sticking to the 65-70 range on the highway consistently until I get this all figured out.
If you didn't test and record your mileage before you got the level & tires, unfortunately you will never know exactly what your truck was getting stock. Mine is still pretty stock, also with soft tonneau cover. If I set the cruise at 70 and drive for 2+ hours on the freeway, I have hit anywhere from 19 -22 mpg on a full tank. Mostly depending on wind conditions, but around 19.5 - 20.0 would be normal. I have the 5.3 with the factory rubber. I can't wait to put some real all terrain tires on and compare my changes.
The 1.5-2 mpg loss for a level & tires is a minimum. It can only get worse from there. Your tires probably are causing you that much of a handicap. The width and tread pattern matter a lot on the highway.
  • 11 months later...
With my 5100’s and 305/55-20s I get 13 on the highway. 5.3, 3.42 gearing but I also set the cruise at 74
I have a 4.5" Zone with 33" Nittos and 22" AF's. I have the 6.2L with 3.23's and the 8spd. If I set the cruise to 75 i'll average 17ish MPG's
2018, CC SLT 6.2 4X4, 2.25” level, +1 offset, 285/60/20’s 23 mpg highway at 65, 21-23 depending on terrain at 72+
SuperChips performance and use Lucus fuel treatment every other tank.
  • 1 year later...
Got this issue also now. I used to get about 15 MPG city and about 18 MPG hwy if I was lucky. Suddenly i'm getting about 13.5 city and 16 hwy.. Not sure what happened...
Configured:
2015 Sierra 1500 5.3L Z71 (Not sure on gear ratio)
1" level (I think from factory)
33" X 12.5" Toyo open country AT2
Not sure what do with this. If anyone has suggestion or thoughts please let me know what could have happened suddenly to drop in MPG. I would like to know before I make a 1200 mile trip.
Unrelated note: Just took the vehicle to the dealer for the recall on brake pedal pressure and oil change and rotated the tires. Said emissions was fine and nothing seemed off.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
