Hey Phil sent you a PM for a harness.
Thanks....
Thanks! I’ll get to it shortly.
Phil,
are you still fulfilling orders for your jumpseat plug and play harness? I would like to order one
Yes sir. But due to the demand, I am 12-15 days lead time for new harness orders. Then factory 5-7 day shipping. Saw your PM and responded.
Hey Phil needing to get a harness and possibly the whole console from you.  Will send you a PM.  Thanks
For those also interested in the wireless charging upgrade I have some decent news if you have a Galaxy S10 (specifically the E version is the version I have). I bought my console with the first generation wireless charging with a plan to update it as it wasn't working for my previous Galaxy phone. However, the S10E even with a case, fits and charges wirelessly.
I just received my center console.  I was pretty confident after watching pgamboa's video and then I got this.
First pick is the console.  It's out of a wrecked '16.  The second is what i believe is the the mounting bracket for attaching to dash.  I have no clue what the silver bracket is.  Then I got a bag of screws and bolts.  If anyone can tell me what that silver bracket or where all those bolts go, I will definitely be appreciative.
The silver bracket goes underneath towards the back of the console.
Middle bracket
Rear bracket
The four nuts with washers hold on those two brackets.
The black bracket looks different than the one I have.
The middle duh!  That takes care of most of the silver bolts.  Any clue what all those black screws are from.  Told the guy at the salvage yard I needed that black bracket and the bolts holding it on and I got a big bag of crap!
Some of the black ones hold on the front bracket you have there. The rest, no idea.
Can anyone tell me which part numbers match up with the attached color code for the new center console?
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
