RC coilovers on a BDS kit?.....blasphemy!  [emoji23]
Contact BDS/Sport Truck USA and get the matching Fox coilovers and Fox 2.0 rears to go with your kit.
They’re dragging their feet on getting them out. I’m actually thinking of calling king to get a set.
4" BDS lift with fox shocks. 20x10 wheels, -24 offset and 34" ridge grapplers (295/60/20). Front wheels took a 1/4" wheel spacer to clear the caliper. I tried 35s and they didn't fit, would've required massive bumper trimming. The 34s still required trimming the plastic, removing the front mud flaps, and trimming the inside lower corner of the metal bumper to eliminate all rubbing.
Once I wear these tires out I will probably go with the 35s and trim the bumper more, but wasn't prepared to cut it yet on a brand new truck.
I have fox 2.0 on rear. Not a fan. No adjustability and there coil over reservoir are to pricey for me. And they are not available.
You are not a fan of the 2.0s because there is "no adjustability" but you then state you don't want to spend the money on adjustables.  Not really fair on the poor ol' 2.0s!  ?
Champagne taste, beer budget!  ?
On 8/27/2019 at 5:15 AM, TheElementalCashew said:
6” BDS and 20x9 Fuel Rebels with 35” Nitto Ridge Grapplers. I need to do some coil overs on the front.
This sits perfect. Let me know what coil overs you decide to go with.
On 8/8/2019 at 10:10 AM, foxcoupefan said:
I am definitely a form follows function guy. I wanted a fast dirt road truck that wasn't too over the top for the street. I wasn't going to do an upgrade unless it helped the truck in terms of functionality.
I went with the Baja Kits Chase kit (Baja Kits Control arms, BK's King 2.5 Remote reservoir coilovers, BK's rear remote reservoirs and 35/12.5/17 KO2s). About 3in in front and nothing in rear. Adding a 1" of lift in rear via Deavers/block.
Incredible ride for sure. The quality of Baja Kits and King stuff is just over the top. Customer service is top notch as well over at Brenthal/Baja Kits.
Btw, Wheels are bronze Method MR312 in 17s. Super dirty so hard to tell in this photo. Thanks for looking and have a blessed week!
Awesome set up. I was eyeing this kit, the camburg or Mazzulla. Is your truck a Trail Boss?
you have a very nice setup!..how did you get 3in in front from kings?
am going with filthy motorsports custom valved slightly extended kings 2.5 on JBA uca but was advised against raising kings to 3 inches...….everything ive seen is 2.5 inches max....        rrrrrrrrrrrrrrrrrr
I found this on the mazulla site. Looks like they offer the Kings in a 3”
https://mzoffroad.com/collections/chevy-gmc/products/king-2019-chevy-gmc-1500-3-0-front-coilover-shock-33700-132a
4” Ready Lift with 295/65/20’s with -18 offset. It rubs and my fiancé laughs at me.
Just shot these today, if anyone in the New Jersey area wants to meet up for photos hit me up!
-Dennis
Edited by SatinSilvy
-Dennis
Very nice looking rig. Not a big fan of chrome bumpers but your body color and lift look amazing with the chrome.
Thanks! I’ll be deleting chrome as time goes on. Can’t do everything at once, gotta have things to look forward too. I’ll end up buying new bumpers maybe some sort of aftermarket ones.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
