I ended up installing the BoostAuotParts wireless charger over the weekend. Their install video was great. I suck at drilling plastic apparently. Luckily that's hidden and I was able to salvage with a file and razor blade.
The only knock I have is that it resets/turns on every time the truck starts, including from the auto stop. So changing mode to mode 2 or turning it off is pointless until it's going to be sitting a while. I might put a switch on it.
On 7/24/2021 at 1:25 AM, Transient said:
Just got all the parts and will soon be joining the group of people that did the conversion
Good luck on the build.  I have ordered all the parts, except for the air duct (Part No. 23391625).  Where did you find that one?  Several dealers have told me that its on backorder with no available date, and have cancelled the order.  Any suggestions?  Thanks.
Edited by Legal4u
Correction
You probably don't need the air duct unless you live in death valley. I ran mine without duct and it wasnt bad.  It is actually a little tricky to get to where duct plugs into hvac.  you have to remove glove boxes.  Could try without and see if you feel charger getting overly hot.
Would be great to see pictures of your install if you’re willing to post. Especially interested to see how you route the air duct if you decide to install it.
Also what hardware you use to attach the charging module to the console. There are 4 screws shown that attach the charger tray but I see nothing in the schematic for attaching the charging module to the tray. Does it just rest in the tray without any screws?
The parts guy I use exclusively at the dealership by my house got it for me.  He knows not to cancel my orders.
I'm not too far away from Death Valley, and drive through the desert occasionally.  I'll let you know how it works out.
I'll post up what I find out when I get to doing this project.  I've had a lot going on with family, and it affected my health.  I'm getting over it now, but probably won't be able to tackle the project until this weekend.  Wife thinks I may have contracted COVID based on my symptoms.  She's an advanced practice nurse, and may actually know what she's talking about, lol.  It's been a fun debate of her demanding I get tested, and me telling her to pound sand.  I've done what I would do with any illness -- isolated myself, slept a lot via frequent dosing of nyquil, and remained hydrated.
I finally got around to doing this install today, and I'm going to have to do it again.  I blindly took the part numbers that were given in this thread and placed an order with my parts guy.  He got everything I asked for, but one of them doesn't work for me -- the wiring harness.  The harness I ordered doesn't have the connections for SD card reader, so I lost my factory navigation that I upgraded to and installed a few months ago.  Doing some research I found out there's about 4 or 5 different wire harnessed that got used in this area.  You either do have rear heated seats, or don't.  You either do have a wireless phone charger, or you don't.  But, there's nothing mentioned about the SD card in the bin under the armrest.  Finding the correct harness will take a little effort.  Fortunately, I love redundancies.  Not only do I have Android Auto to help me l navigate me, but a recent update from Chevy provided those without navigation a navigation system that doesn't require the SD card and programs module.  It's called Chevy Maps+.  Iirc, I found it in the marketplace where you can add other apps to your radio screen.  It's actually a pretty good navigation system, and gives those with IOS radios but not the fancy instrument cluster the speed limit of the road, and your speed, right there on the navigation screen.
Sorry about going off into left field there.  Back on topic....
This project is more fun than I cared for.  I'm debating whether or not I want to install the hvac tube, but that's minor compared to this project requiring the removal of the entire center console and the front passenger seat.  Yep, you read that right.  When I finally get the correct harness, and go to install it, I'll try to get a bunch of pics and do a write up, including what tools I use.  The good news there aren't many tools needed, and it's not a tough project.
As for questions about the charging module being secured, the answer is it just sits in the tray.  However, the tray gets secured to the top cover via screws underneath.  I just happened to have screws small enough and short enough sitting around that I was able to secure everything together.
Update:  I definitely need to get the hvac tube installed.  Went 4 wheeling in the truck today.  Had my phone sitting in the charger for several hours.  It ended up getting hot, both my phone and the charger.  And, it was over 100° in the area I was 4 wheeling, however my truck had the ac blowing at 69° the entire time.
it will be interesting to see what it takes to install the tube. Appreciate your willingness to be the test subject.
So I got everything working but the air duct.  I could not figure out where it goes.
Anybody got pictures of where it's supposed to go, or how it connects?
Would greatly appreciate it.
you need to pull out glove box.  on the hvac body there is a white plug(i think) in the hole.  pull plug and that is where it goes.
Top or Bottom?
I tried to take the bottom one out but couldn't get it to come out.
I pushed in the tabs and got it to hang down but couldn't figure out how to remove it.
Did you ever figure out which harness you needed? I have the same issue. Harness I ordered has all the plugs needed except the one for the center console USB ports/SD reader
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
