I jumo started a car with my 2014 GMC Sierra. While jumping it I noticed that I couldnt press the accelerator to give it more juice. I unhooked the cables and realized that the powersteering and the accelerator would not work at all. I turned my truck off and then back on ,but the problems were still there. I now cannot get my truck to even attempt to turn over, but the battery and fuses have been checked and are good. Any ideas on what the problem could be?
You may have fried any of your electrical components. Don’t ever jump start anyone with a modern car it always risks your electronics. You’ll need to take your truck for diagnostic.
  • Thanks 1
This.
Lesson learned the hard way.
This.
Sad but, true I was almost victim to this on my old truck. Never knew it wasn’t safe to jump people. Bought a noco jumper pack and keep it charged up in the back seat.
Have to follow the steps in the OM exactly of you risk what happened to you.
7. Connect the red positive (+) cable to the positive (+) terminal of the vehicle with the dead battery. 8. Do not let the other end touch metal. Connect it to the positive (+) terminal of the good battery. Use a remote positive (+) terminal if the vehicle has one. 9. Connect the black negative (−) cable to the negative (−) terminal of the good battery. Use a remote negative (−) terminal if the vehicle has one. Do not let the other end touch anything until the next step. 10. Connect the other end of the negative (−) cable. 4.3L Shown, 5.3L and 6.2L Similar ‐ To the metal bracket that is bolted to the engine and supports the resonator, on the vehicle with the dead battery
Jumper Cable Removal Reverse the sequence exactly when removing the jumper cables. After starting the disabled vehicle and removing the jumper cables, allow it to idle for several minutes.
I carry a lithium jump box because i've heard this before. I also carry jumper cables, for someone else to use, with someone else's car at their own risk.
These little things will not properly jump start a gas or diesel V8 engine and it's low voltage can cause damage.
You need a REAL jump box, something like this:
It is important to look at the number of required cranking amps (CA) before buying a jump starter, That’s especially true in a diesel engine, which is harder to start. The required CA varies with the size and/or type of the engine which you are looking to jump-start. If insufficient, you won’t be able to start your engine no matter how hard you try. Today we’re looking at the best portable jump starters for diesel engines.
Diesel Engines have a bigger compression figure than Petrol Engines. So, they require a significantly greater number of CA than gasoline engines of the same size. According to an estimate, diesel engines require double cranking current than the petrol engine of the same size
https://www.amazon.com/dp/B000KPSA0W/ref=as_li_ss_il?ie=UTF8&linkCode=li3&tag=turbogadgetre-20&linkId=e065bf83c7d6a105b4618a84a8f6a62c&language=en_US&th=1
Is the truck running during this process.? I would assume so.
Sent from my SM-A705W using Tapatalk
Sorry, did not include that part:
11. Start the vehicle with the good battery and run the engine for a while. 12. Try to start the vehicle that had the dead battery. If it will not start after a few tries, it probably needs service.
This is done after cables are connected.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
