so from what I get out of this, they know how to fix it, they just don't want to
hahah yes, I do have multiple of them
I think the real issue is GM along with consumers are giving some of these technicians too much credit. I was speaking with a ASE certified technician about the issue and could tell instantly that he did not have the knowledge or experience to go beyond blaming the tires. Being ASE certified as well I know for a fact that there are many techs out there that just studied the testing guides and passed the certification test. I honestly believe very few technicians out there will actually know how to diagnose and repair the more serious issues that cause vibrations and drive line phasing problems. Its just easier for them to save face and say "Normal Condition" "Its a truck" "No issues found".
Well then GM owes me a set of Dueler A/Ts and they can take back these flawed SRAs. They definitely are not all terrain tires, and surely not an upgrade either. Right now I feel I have been ripped off for $200.
Can anyone else chime in if you ordered or have a truck with the $200 all-terrain tire option (code RC7)?
My truck's window sticker lists all terrain tires and it came with the Bridgestone Dueler A/Ts. I swapped em out for larger Toyo Open Country A/T II's though. But in any case I think you should have gotten the Bridgestones and not the GY's. I'd go talk to the dealership.
whether that's true or not isn't really our problem, we all want our trucks fixed. I believe at this point we can technically all take our trucks to our own repair shops and have the work done, and just send GM the bill, but i can obviously see issues with that as well
Headed to the dealer as we speak for my vibe issue. This ought to be interesting. Gonna fill it up and reset the trip before I go in. Also note what the mileage is before I leave to see how much effort they will actually put into it
How tall is that ? They list all of their 4x4's as 78.5 inches tall. Just curious how accurate that is. My garage opening is only 77 inches, the Silverado's and Tundras fit. I don't think the Ford or Dodge would.
I'm sorry not sure but it does fit in my garage but I have a taller door I believe .
When I get home tonight I can measure my truck if you like .
I know it does sit high stock though because I need to grab the oh shit handles every time I get in and out to avoid sliding on the side edge of the seat and avoiding a little free fall of airtime lol . I'm only 5'6" though and see some iron cross HD steps in my near future .
Edited by TheFactor
Good luck I hope they get a fix for you
I have the goodyears on my truck too and they charged me $350! Must be more for those fancy white letters that no one likes!
tlake84 window sticker
To a point, if the dealer wants to keep his franchise agreement they have to play by
GM rules...period !
On the flip side sadly, to many ' Tech's ' today are nothing more then parts replacers.
IMO, There is a combonation of issues going on here, frame, driveline, wheels & tires
until it's isolated it will only compound the dis-satified customers that there seem to be
more of everyday. It was not until I pointed out the safety concern that GM took me serious
and this was after I drove the truck with the service manager and once the vibration started
@ 75mph I started switching lanes back and forth and you could actually feel the back tires
loose contact as the vibration became a feeling like it was riding on blocks.
This was all under 500 miles and the fourth time in for what they deemed " Normal Opperation "
I respectfully asked the service manager that if this was not a concern that I'd be more then
happy to take ANY GM Engineer for the same ride...of course this would never come to pass
and they wrote the check and sold it to someone else.
Edited by Enforcer
Truck goes in for it's first service this week, I'm going to talk to the service manager about my vibration issues and the vibration data I have already gathered. we shall see if I get the "I've never heard of this before" or drove the truck and didn't feel anything, operating normal. I pulled all the aftermarket suspension parts off and reinstalled all factory components and factory wheels and tires, vibration is still there at the exact same frequency. I even put the truck and jack stands to eliminate the road surface and ran it at 70 mph, and guess what... vibration at the same frequency all though the amplitude was less severe. Not sure if anyone else has tried it but when you run the truck with the wheels off the ground the computer freaks out, turns off stabilitrak and traction control and every other feature, disables the steering assist and flashes calibration mode and says you need to service this, that and the other even disables the lane control, parking assist and trailer brake controller, everything went back to normal after driving it a few hundred feet. I'm convinced its a rear end issue in my case, hopefully I can convince them to bypass the multiple sets of tires and countless rf balances and go strait to the rear end. If they don't have a pico I might try another dealership or just take it straight to a local rear end shop and pay them to open it up inspect it and let me know what they find.
I have a 2015i 3500 4x4 srw Duramax, been vibrating since I brought up to speed with 148 miles on clock. Mine was a multifaceted problem that was a combination of the Good Year crap tires and a bent rim. After replacing rim and installing a set of Nitto Dura Graplers at my cost, the heavy shaking was removed only to discover the "rumble strip" driveline viberation. This has been noticed since around 5000 miles, now at 31,000 on the odometer. I have been to dealership 4 times only to hear "can't duplicate" , "normal operation". The vibe begins around 67mph and continues up to it phases out around 75 mph. Well everyone else that rides with me can feel it. I use a old school truck alignment shop that still strobe balances the front tires(spin up tires approx 80mph on truck). During the last 2 visits, the very experienced tech felt the vibration coming from passenger side front axle. Upon placing stethoscope on housing extension he felt the needle bearings that support axle shaft in housing is the culprit. Back to the dealer with the news, and they are refusing to address. They don't have a strobe balance machine to replicate, and won't send someone over to the independent shop to observe. And to top it off, found the dreaded rear main seal leak on the Duramax. I am sick, $54,000.00 investment, this is deplorable.
2015i GMC 3500hd cc4x4 Duramax
You should seriously initiate a case with customer care about this, and immediately have it escalated to a supervisor. I just got done with a chat with TireRack support:
Thank you for choosing Tire Rack. A product specialist will be with you shortly.
You are now chatting with 'Ross'
Ross: Hi, how can I help you today?
Mike: Good morning Ross
Ross: good morning.
Mike: I have a question regarding all-terrain tires...
Ross: Okay
Mike: Are all-terrain tires branded with a special mark or lettering?
Mike: Or specifically, are Goodyear Wrangler SRA tires "all-terrain" tires?
Ross: No
Mike: I noticed most all terrain tires have "A/T" in the name...
Ross: No, the SR-A tires are just standard highway all-season tires.
Mike: Ok thank you for your help Ross
Ross: Is there anything else I can help you with today?
Mike: No that is all, thank you
Ross: thank you
Ross: Thank you for chatting with us. We value your feedback. Please click the "End Chat" button at top right to answer a few questions about your experience with us today.
Thank you for chatting with us. Please click the "Close" button on the top right of the chat window to tell us how we did today.
The chat speaks for itself. If GM is going to sell customers an option for "all-terrain" tires, and are giving them cheap standard highway tires, there is something wrong there and customers are getting cheated.
Huh yeah i have the all terrain W.O.L. tires listed on my sticker but have the SRAs...... anyone have info on this?
I'm in a dispute with GM regarding this. Goodyear Wrangler SRA tires are not all-terrain tires. See my chat above with TireRack customer support. You can also search for all terrain tires on their website, and the Goodyear SRAs do not pop up as a choice for all-terrain.
JesseD mentioned that previously, trucks were being built with Bridgestone Dueler A/T RH-S tires, which are in fact actual all-terrain tires. They are also around $20-30 more per tire. A fair upgrade and at least you are getting something extra for your $200.
My theory is that GM has had such a cluster-bleep with the Goodyear SRA tires (it is a documented fact that large batches of these tires were produced out of spec, and are impossible to balance), and so many customers have complained, that GM is now throwing these tires on as many trucks as they can, so they can burn through them...and then stick Goodyear with a nice bill for all the defective tires.
Either that, or GM simply made a mistake and started building trucks with the all-terrain option, with non all terrain tires.
Either way, you should complain if you got SRAs and paid for all-terrain...because you got ripped off.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
