This was posted in another thread recently. I believe southern sierra's vibes were cured by torquing the u-bolts too. I know spec is 78 ft/lbs and I have tried my with no luck but the highest I have gone was 95 I think. I know southern Sierra torqued them down as tight as he could so maybe they are onto something. I might try cranking mine to 120 or so this weekend and see if it helps. Worth a shot and it's free.
Not too sure about the quality of the GM U-bolts, but couldn't cranking them that tight potentially cause some type of other issues, whether it be with weakening the bolts themselves, or something?
Took my 2015 Silverado in this morning. They are going to do the Road Force tire balance. I'll post the results.
I'll tell you what will likely happen....
They will RFB the tires and check the wheels for roundness.
They will determine that 1 or more tires is way out of spec (excessive road force) and replace them with ones that are "in spec" (note that GM is now using much tighter standards on their tires than any other manufacturer including the tire manufacturers them selves) because they feel that it is the a cheaper hopeful fix for them
Now the dealer will call you and say that your truck is all set, and the vibe is/ should be gone.
You will go pick your truck up and begin driving only to find that the vibe is still there... possibly reduced some, but still there nonetheless.
You will come back here saying the vibe is still there after the dealer replaced X number of tires.
Now you will be contacting the dealer again to get the truck in again for another "fix" that likely won't work.
Sorry to be the bearer of bad news, but this is happening so often, everyone knows the process by heart now lol.... Good Luck though, lets hope I'm wrong and you're one of the very few lucky ones.
I got the same vibe from reading this thread. I already have the Lemon Law form ready to fill out for each visit and I'm making sure the work orders from the dealer specify what I went in there for. I hope this doesn't go that route because I love my truck. I do find that the vibration is intermittent and only seems to show up when the truck is having to push itself. The infrequency of it bothers me a bit because that just tells me it will be harder to figure out. It also doesn't seem to be as much of a shake as other people might be having.
Are all of the GM/Chevy trucks doing this?
Gm customer service is useless,I have been dealing with vibration on my 14 Sierra since new. I finally contacted the bbb and guess who calls the next day. After a couple weeks of back and forth the rep tells me yesterday there is nothing wrong with my truck and he has nothing to offer for the countless times at the dealership for the vibration and many other issues and I need to go toward with the bbb since I didn't like his answer. My truck is in the shop right now and the 16 sierra I'm driving is also a vibrator with wheels.
I dont want a new truck, I have to much money into this one. I want my truck fixed and I want to be compinsated for all the troubles I have had over the past two years. I didn't buy a new truck to go to the dealer every few weeks and get crappy rentals.
You will be dealing with engine problem instead
http://oppositelock.kinja.com/ram-vm-3-0-fatal-engine-failure-flaw-1755232142
May be you will be ok if you buy their lifetime warranty, you will need it
I traded my 2014 Silverado for a Ram R/T 5.7. Very few people got the ecodeisel and I did read one member of a Ram forum had a failure with that engine. I'm certain Chrysler will actually find a fix if they haven't already. The 3.6 V6 and the 5.7 V8 are very good engines. While I've had mine I found one defect that was actually fixed by the dealership and one recall that was also taken care of. It is the best truck I've ever owned and I've had many Ford and several GM. Extremely smooth ride and completely unlike my Silverado experience of endless recalls and many defects that could not or would not be fixed. So trash the Ram's if you want. But everyone must make their own decision on what is in their best interest and go out and check things out for themselves. There are fan boys of every make. I go to the brand that dumps on me the least at the time and that ain't GM as is evidenced by this entire thread.
I have had my 2015 Silverado Crew Cab LT for a month and it has this console shaking issue. Taking to the dealership in the morning for that and a seatbelt problem. I'm not able to read the entire 515 page thread from 2013 until now. Has anyone been able to remedy this issue? I've seen some people talking about this buy back thing or tires/drive shafts out of alignment. I really love my truck and I don't want to give it up.
It seems to shake between 70-75 mph, but not all of the time. Sometimes it's more shaky than others. I've also been on smooth asphalt back roads and not felt it at all. Could it be something to do with rough concrete highways send the tires or something out of whack? I had a 90-something GMC a while back and the steering shook with the cab. Found out it was bad back tires.
You describe mine except we get the vibration in the seat at freeway speed of about 80mph. Mine is not the drive train because it is smooth on good roads and worst on a road with small evenly spaced ridges like concrete road joints or asphalt seams that start to appear where each separate pad of asphalt starts to heave with age. More noticeable in winter. I'm baffled on this one wondering if it's the Mag Ride shocks. Seats aren't real solid so maybe another possibility. At first I thought it was driveline or rear end but mine only vibrates at 80+ or - 10 and only on certain rough roads. Running my Michelin studless tires that didn't vibrate on my 2014 so not them unless I'm beginning to get some tread separation. Nothing visible on exterior of tires and just drove 1500 miles with no change. Maybe the stiffer body mounts contribute but my 2014 was identical truck except for the Mag Ride shocks on my 2016. Any other thoughts?
at this point I'd take a f*cking FIAT over a GM POS. lol... maybe thats a bit extreme, but I would definitely go back to my 9 year old car.... or the other 15 year old truck we traded for this POS
"i'd take a dodge 5.7 over GM's"
I'd take my 2,000 shares of GM common stock that turned to dust in 2009 back in cash for what I paid for it. Like thousands of other folks, lost this out of my 401K. Ooop's, think I'm on the wrong blog. Sorry !
Correct me if I'm wrong, but I believe your experience is not the norm. Most folks with the 70+ mph vibration don't seem to get it resolved with balancing and/or new tires. Does make me wonder if the people doing the balance (on the ones that don't get fixed) are doing it correctly! We've discussed that numerous times before on this thread. Still a question, in my mind.
Wrench... Nope, you a definitely not wrong... I follow this thread daily and maybe 10 were fixed with a tire Balance... One of my wheels were out 1 1/4 OZ which is a lot from what I hear... My Vibe was really really bad..
no way i'd take a dodge 5.7 over GM's
Well I assume that means you were lucky and got a good one. Great, stick with it and enjoy it. All I can relate is my experiences with GM. The first new vehicle I ever bought was a 1981 El Camino. I found eight defects just on the way home from the purchase. It had an engine knock that they could not fix and then stated it was normal. When I washed it the wipers would come on. Sheet metal actually cracked. And on and on. I swore off GM until 2010 when I got 35% off on a new Silverado. Although the engine, suspension and materials were antiquated, and the ride was more choppy then a row boat at sea, I actually had no problems with it. So when the new style came out in 2014 I traded for one of those with a 5.3. I did like the gas mileage and the ride was improved and I had no problem with the 6 speed trans. As I mentioned before due to all the unfixable problems and endless recalls, I had to part ways. I went with the Ram because after a lot of research on direct injection engines which are found in all GM and all Fords except for their 5.0, I knew I wanted to check out the Ram because it still has port injection and so will not suffer the inevitable carbon buildup problems your direct injection will have. I was surprised at the higher quality of the interior, electronics and suspension of the Ram over the GM. So, I'm happy you like your GM but in a way it was a good thing mine had so many problems or I would not have discovered a better truck for less money. I still come on to read this thread just because it's hooked me like a soap opera. It's like the battered wife who won't leave her husband because she loves him and thinks she can fix him. Same thing here. "My truck and GM treat me badly but I love it and if I just keep changing parts out on it over and over, someday it'll be the truck I married".
Edited by mjb4450
The best vehicle is the one you have no problems with.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
