What did you pay out the door? Or I guess a better question would be what was the agreed upon price of the truck with all the accessories?
Edited by dave07
That my friend is a long story... however I will keep it brief. they screwed up in their online ad (forgot to add the value of the accessories to the cost) in dealership they wanted $53,000. probably would have got it for about $51,000 had they not made the mistake, because of the mistake, I paid substantially less (consumer protection laws require them to sell it for the advertised price, mistake or not), not that that is of any consequence, because it is the current cash value of the truck that is in question, not what I paid for it due to their negligence.
The extended warranty is not included in that cost either.
Edited by Jesse D
So, I'm trying to get up to date on this issue. I've scanned this thread but there are 547 pages! Can I ask some simple questions, which might be helpful for others trying to gather info on current status.
1. Is the vibration resolved by changing to some higher quality tires?
2. Do the new 2016 trucks have the same problem?
3. GM has not been successful in tracking down the source of the vibration, in most cases?
thanks
thanks
1. No
2. Yes
3. Correct, unsuccessful in fixing the issues
What is a 3rd order vibration? I don't understand why they can't fix this crap.
Simplest terms a thrid order vibration is when the vibration frequency is 3X rotation frequency of the part causing the vibration. Example: tire rotates at 10 rotations per second or 10 Hz, First order vibration detected at 10 Hz is usually a mass imbalance, Second order vibration is detected at 20 Hz, Third order vibration is detected at 30 Hz, and so on.
Well I had an update call today from the dealer stating that gm thinks it's no big deal. I call bs!!! How is it not a big deal when all you need to do is Google search silverado shake and tons of links pop up and videos. We all must have no idea what we are taking about. So they want to run another picometer test and send it to gm. Guess who doesn't have thier truck? This guy!!! Has anyone towed a heavy load with the shake? Does it shake more? I'm starting to wish I never bought this truck.
My truck shakes less when towing.
Probably because you have substantial tongue weight on your hitch which has the same effect as load in your bed.
thanks
1. No
2.Yes
3.Yes
Actually, it was small. A 4x8 UHaul trailer with a sofa and it titled up slightly, but it was enough to make a difference.
Edited by GMCSierra4x4
FYI if one happens to go through the BBB and a repurchase is granted you can go after every penny invested in the vehicle. This includes wheels, lifts, tint, etc... It's part of the "collateral charges" you may be entitled to if the BBB finds that the vehicle is in fact a lemon.
Edited by ekimsinnigcm
thanks
You are in for a long and very uncomfortable ride.
1. No, because GM says there is no vibration issue
2. Apparently so, nearly a million hits on this site alone tells the story
3. No, because GM says there is no vibration issue
Some dealers are trying to help, mine has dumped me.
BBB arbitrator sided with GM (follow their funding and you'll see why)
State Attorney General's office will do nothing
Until this thing hits GM squarely in the wallet, they will do nothing
Bottom line: you're stuck...
Does changing to aftermarket wheels help?
Does it happen with the smaller 18" wheels?
Does it happen on both 4x4 and 2wd trucks?
Does it happen on all wheelbases - reg cab, DC, crew, crew long bed?
thanks
I bought a new 15 sierra 5.3 rcsb 4x4 at xmas and only got a chance to drive it 200 miles but it has no vibration. But I can tell these new fully boxed frames are very rigid and don't flex. Something tells me because of the nature of fully boxed frames all road , tire , drivetrain vibrations and harmonics are going to be transmitted to cab. This might be a crazy thought and probably is but maybe cab mount material will have to be rethought to cancel and absorb these harmonics better . Just a unscientific thought at best LOL.
Update: vibrations came back. Thoroughly disgusted with this truck's vibrations. On my drive yesterday morning, it shook so hard, it felt nauseating. GM lost their ability to build a good truck, imho. As there's no effective repair yet, the thought of ditching this silver colored turd is tempting.
The 5.3 and 6.2 are direct injection engines. Gas is not sprayed on the valves to clean them. The gas is injected between the bottom of the valve and the top of the piston. On the older engines the valves were washed with gas. Some people including me are using catch cans to try and keep the valves from coking. The valves can be cleaned using seafoam through the throttle body.
Lesson learned.
Sorry buddy, that has nothing to do with the Vibrations talked about in this thread. Your vibe problems sound similar to mine in that they come and go.
You are so right about come and go. Kind of like a bad girlfriend - stays around too long and comes back too soon.
so suffer another year, and hope you still have enough time left to file for it.
Im sure someone out there has aftermarket rotors by now..... I tend to doubt that they are the issue. I believe it was abominable that took is rear end apart and found the edges of the gear teeth chipping away... GM said don't worry about it lol.
Gas has nothing to do with it, for that matter I only use "top tier" fuels in shell, mobile, and sunoco. doesn't help me
This i agree with
I know people have used lift and leveling kits, but has anyone tried using a softer shock, and adding sway bars to reduce the additional body roll that would likely result. leaf spring clamps have helped some people.
just spit balling here
Yup, thought fuel would be the source but not even close.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
