Hello Puckstop,
I am sorry to hear you are experiencing these concerns with your Yukon. Though, it’s good to see you have brought it into a GM dealership to get it serviced. I would be more than happy to offer additional assistance if you need any when working with your dealership. Please private message me with more details if this interests you.
All the best,
Julianne M.
GM Customer Care
Just dropped off my 2015 Yukon for a vibration in the rear. Noticed it the day I drove off the lot. It wasnt entirely consistent but started at 70mph thru about 80mph. I figured it was just a tire balance issue until my service advisor called me today and told me it was a known problem and they would do what they can. I have 2 other issues with it as well; the bottom 3rd of the radio/gps display will flicker from time to time and when I plug a phone into the usb ports, I get a frequency feedback thru the radio. Tried multiple cords and phones with same result. Anyone else have similar issues?
traded in my '14 double cab for a '16 crew cab last week....left the dealership and about 10 minutes later noticed a horrible shake vibration when in Drive stopped at a red light. Truck had 15 miles on it....ugh.
nasty nasty rough idle.
Took it in on yesterday morning, they spent the day doing repair PIP5211D, replacing motor mounts and adding shims. Seemed to do the trick. Drove for about 40 minutes in stop and go traffic. No vibration or shake when idling......until the 45 minute mark. It's back. Not as bad, but still very noticeable. I'll see how the drive home goes, but I have a feeling I'll be bringing it back sometime this week.
THE FRUSTRATION!!!!!
Well, turns out after driving for 10 minutes or so, the rough idle returns. Looks like I'll be taking it back to the dealer again this week. Not looking forward to them telling me this is normal. My '14 did not do this.....
Fully boxed frame
Newly designed cab mounts
New cab design
Just a few big ones
Did the steering system not change as well? I thought it went from a rack and pinion type to what is on it now...could be wrong but it looks different to my inexperienced eyes
The power assist is via an electronically controlled motor, not hydraulic by a belt driven pump.
Ok, so as promised I went to a local tire shop (anyone in the northeast you probably know Sullivan Tire) I didn't have them change any balancing or anything. I just merely wanted confirmation that the tires & rims are true and in good standing.
heres the results :
Tire Location: inner weight reading outer weight reading RFB number
LF needs another 1/4 oz perfect 23 lbs
LR perfect perfect 25 lbs
RF needs another 3/4 oz perfect 25 lbs
RR needs another 1/2 oz perfect 21 lbs
By both GM and Sullivan Tire standards these tires meet spec. although a 25lb rfb number is the upper limit for GM, industry standard is 30lb. Because the truck still vibrates, we now have definitive proof it is not related to the tires, although properly balanced and lower rfb numbers do help to reduce it.
One of the guys I spoke with at Sullivan Tire knows quite a bit about the Vibration issue, saying that they have a few sources within GM itself, and the Engineers there really have no idea why the trucks are doing it, and that they know its a big issue.... just some food for thought.
heres the results :
I could have went to the Adult Mart and spent $30 to have the same tingling in my ass!
In your ass? Wouldn't ya rather go to the Adult Mart and get a tingling on the johnson?
heres the results :
Interesting. My dealership told me tag 15lbs RF was the target for K2xx trucks. They even replaced 6 tires to get them all under that.
This did resolve my 'buffeting', not the vibration which was fixed with a complete rear end exchange. [not in any way related to the last couple of posts referencing rear ends] ;)
My dealer said the same thing, 15lbs.
I've never heard 15 lbs ever, thats half the industry standard
And I've never owned a vehicle that required road force balancing!
  • Like 4
heres the results :
Don't quote me on this, but I think 25lb is the normal GM limit, but one of the TSBs on this vibration issue says that for trucks and SUVs with vibration and/or booming-pressure issues, to apply a lower RF limit 15 lb I believe).
One thing I haven't seen anyone posting is if the results of there RF is 1st order, 2nd order, or 3rd order. I am pretty sure that the Hunter machine will measure all three orders and report if the operator sets the machine to do so. If not, I think the default is to report 1st order only. And, I believe same applies to the balancing: 1st, 2nd and 3rd can be measured, but not by default. So, I wonder if if something is being missed if the shops are only looking at 1st order on the Hunter machine?
Also, don't forget, it is not a Road Force Balance! Balancing is a totally separate step and consider mass unbalance, not Road Force Measurement. High Road Force cannot be corrected with weights. Correction can only be done by indexing the tire differently on the rim,mswitching the tire to a different rim, or replacing the tire. In some case, the RF will be what it is. So, the shop can't always correct it, short of going through a stack of new tires until they find a good one. And that assume the issue isn't the rim itself, which can also generate a high RF (but that easy yo catch by measuring the TIR of the rim without the tire on it. Assuming the shop biters to do so. Another step in the flat rate work they are doing!)
Of course, we all know there does not seem to be any other vehicle that requires such perfectly balanced wheels and tires with such low RF values, so there is no doubt these vehicles are way too sensitive and that is the real problem, not the tires. But, changing tires is all GM can do, since they obviously have not discovered the real "defect", or they have and realize it s not possible, or practical, or economical to correct it.
Well if they really did know the root cause you would think they would have fixed it on new trucks coming off the line. But that doesn't seem to be the case.
And am I the only one who had never heard the term road force balance before 2014 ?
And with that being said, if you buy tires, I would suggest at the dealership.
No tire shop is going to replace a tire that has a RFB of 30. And your local GM service department will tell you that they can't fix the vibration because it is the tires and since you did not buy them there they will have to charge you to get them to 15. If they cant get 15, then you are stuck fighting the tire shop who is going to tell you to fly a kite.
At least if you get them at the dealership, the burden of finding you good tires lies with the dealership. Who must supply to GM specifications...
OMG - I just had a thought, alarming but....
I believe if GM or any manufacturer requires you to purchase a specific product or specification for your vehicle or it will not run properly- they have to supply them. Does anyone know that law?
Here is an interesting read that I found for frame beaming for older chevys, note the lower RFB that GM is specifying.
Boys and girls, the symptoms are very similar to what we are experiencing.
This PI was superseded to add additional info about an oily film on the new mounts. Please discard PIT3009H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models.
Recommendation/Instructions:
The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following:
  1. Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible.
  2. Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate.
Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide:
P-Metric tires (2wd 1500) 12 lbs or less
P-Metric tires (all others) 24 lbs or less
LT-tires 30 lbs or less
If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reduce this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models.
FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS.
New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount.
Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue.
Upper Mount 25791031 Qty 2
Lower Mount 25791032 Qty 2
Washer 15854745 Qty 2 (if needed)
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
