Heres a video of my truck trying a couple things. As you can see the the passenger side minus a flat spot isnt bad. The drivers side however is terrible. Not only is it out of round the hub face appears warped also. I will have it apart for the rest of the day and part or tomorrow if you guys want to see any other angles etc.
Edited by zmnypit
  • Like 5
Is your dial indicator incremented in .001 in? How far out is driver's side it total each way? Can quite make out your TIR (Total Indicator Runout) I agree driver's side O.D. needs to be trimmed and the lateral runout isn't good at all making your wheel and tire wobble. Geezus..!..............
Yeah .001. Drivers side its around .05-.06 on the outside. .04 on the lateral. If you go full screen you can make it out. I'm waiting on my buddy to reply if he can turn then down or not on his lathe.
Edited by zmnypit
Do you have vibration issues, if so, at what speeds?
Thats un****ingbelievable, I seen them out of round but thats extreme.
The lateral is more of an issues because it looks like the studs would have to be removed and removing the metal may become a thickness issue like brake rotors. I don't know what the acceptable tolerances are for the flange thickness.
.040 out for the lateral over say a 7" flange would throw that out three times than that on a 20" wheel (~.125 or 1/8"). So a 20" wheel and tires would wobble about 1/8" of an inch. I'm not a motion engineer but I imagine that would certainly cause vibration @ ~ 70MPH. No?
Holy SH!T thats bad. Is it just me, or does the black portion of the hub seem as though it isn't rotating centered? I blocked out the outside edge to try to minimize the illusion
Very interesting! The 40 thou face runout (lateral, as you refer to it) is extremely problematic. If that translates to the tire OD, as you point out, will be even more movement. No question that will be felt inside the cab!
Now, the flange OD runout may not be as problematic, although there is absolutely no excuse for such sloppy quality. Softail reported he removed a total of 18 grams of material to true up one of his axles. That's 0.6 oz. based on the ratio of radius' between the flange and the wheels, that is equivalent to about 1/4 oz on the rim diameter. 1/4 oz is about the minimum correction weights that can be used, at least in the old days when I was balancing tires. Also, all that weight won't be in one spot. Account for distribution, some will end up somewhat cancelling each other so can estimate the net unbalance to be about 2/3 that amount.
Of course, as vehicles get lighter and stiffer, they need everything to be machined truer and be better balanced. Anyway, it would be real easy to see how much vibration 1/4 oz causes - simply stop by your local parts store, buy a 1/4 of stick-on wheel weight and try it out. If it's significant, should immediately be felt. Regardless, though, I would want my flanges to run a lot truer that 50 thou!!
Now, the hub OD and studs are another issue. In Softails video, can clearly see the hub OD has very little runout. This is confirmed by Softail who said he checked everything and only the flange OD was bad. Which is interesting that his flanges has no face runout.... Anyway, he also confirmed that the studs where running true as well. This is incredibly critical, as the factory wheels are both hub centric and lug centric.
Did you happen to measure your hub OD runout with a dial? Would be interesting to know. I checked the front ones on mine when I swapped the winter set on and got about 1 thou TIR. Didn't check the rear, though. Sure going to now.
All I can say is that GM has to be the worst automobile company in a long time. Machining simple parts like these axles is not rocket science these days, and there is absolutely no excuse for this. Pure incompetence. And GM can blame their out-source supplier but I don't buy that BS. They are responsible to make sure the parts they install in the vehicle are right. Period. Excuses are what I get from my 6 year old. Not what I will accept from a multi billion dollar corporation.
And tomorrow, all the execs at GM will go to work and write themselves some more bonus cheques for doing such a great job...... While you tear apart your new truck to fix their crap. Hmmm. Disappointing to say the least.
Edited by Wrench589
I see one potential issue with your methodology. On the passenger side the hub is rubbing the indicator tip in a downward motion going away from the tip, which is best. On the driver side, the hub is upward toward the indicator tip, meaning the irregularities in the hub are smacking the tip and causing bounce in the indicator.
I would actually put the indicator straight up and down rather than angled, and rotate the axles by hand to get an accurate TIR. Same for the face runout, although your setup on that is much less affected.
I do. 40-45mph and 70-77mph are the more noticeable speeds.
Great video, thanks for taking the time to do that.
You're welcome!
I thought about that. More than likely instead of having them turned down I will just replace them with the yukon axles or aftermarket. I have vibration from 40-45mph and 70-77mph.
I couldn't get it to grab straight up and down. I was able to hold it in place but it was pretty much the same result. I can re-do it if need be spinning the axles by hand?? Once I seen ithe pass side wasn't that bad other than the flat spot I wasn't really concerned about getting the indicator straight up.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
