Just was the post from the corvette owner top of page and that is what was described to me regarding a tooth or gear that was out of acceptable tolerances. Sounds about right
When I get a chance I'll take out the drive shaft and go to a local shop here in Houston Texas and get it checked out. Hope it helps/ it's the solution for me
Here is the update on what they are seeing, he said that seven out of 10 of them tend to be fine, It tends to be more common in different configurations long beds extended cabs double cabs they think it might be related to issues with driveshaft which he said is The longest they have ever been. There is some truth to the issue being caused by tires specifically 22 inch wheel packages with Bridge stone or continentals mounted on them. They have rectified the problem in some instances by putting Michelin's on them. There was some discussion about a bulletin coming out related to the ring gear not being in specification, unacceptable variances on the teeth causing a vibration at speeds. Some of you may know this but GM will put out a bulletin ahead of a recall, if the vehicle comes in with the problem they can fix it per the bulletin but it saves them the money of doing a full recall. He feels there are secondary issues with GM putting too large and too wide of a tire on the truck that is not designed for it but that is more of his opinion. I would be curious as to how many folks with this problem have Bridgestone or continental tires, that may be the best place to start in terms of fixing it, get those tires off and have your dealer spring for Michelin's or a better tire.
GM is keeping a close eye on this but they do not want to address it in mass, and will continue to push the dealers to go with the tire balance agenda
Good luck, I think I will continue to drive my 2006 Silverado for long as I can
Thank you again daleone3! I've mentioned here before that I figured GM and their engineers knew the cause/causes of the vibration problem. I'd bet the fk'n GM bean counters have sat in smoke filled rooms several times discussing ways to avoid the issue as best they can and as long as they can. Pretty sad, especially after we bailed the SOBs out with our tax money. And jerking customers off like they have been, and will likely continue to do, will do nothing but hurt their customer base. Well, at least it sounds like they realize (hopefully) something has to be done.... bulletin will prolly happen sometime after hell freezes over LOL.
Edited by Willyone
I've read a lot of the post on here and my issue a strange vibration around 80-90mph when gunning it. I did get the balanace and rotation done and helped while cruising at 70-80mph. So while driving normal (70-80mph) no vibration at all, really smooth drive but when hitting the eccelarator and gear down shifting getting up to 90mph, I feel a vibration in the rear end which is bothering the hell out of me. It's not a huge vibration but noticeable at those speeds. Wheels are already balanced and rotated and from one person fix was getting the driveshaft checked out and balanced/ fixed.
Also I recently installed RC 2.5" leveling lift kit but I highly doubt the lift kit is causing a vibration while getting on the accelerator at 80-90mph.
I had the same issue and it ended up being my drive line angle was off, I also have a 2'' leveling kit. They put shims in the rear with the larger end facing the front of the truck and shimmed the transfer case up. What was happening was under acceleration while moving the truck that fast the engine was applying a lot of torque to the rear end which twists the rear pinion upward and makes the drive shaft angle off. Mine would only do it when i was traveling 75mph or more and accelerated hard. The joints need to cancel one another out with torque applied to them. I also have the 6.2 engine with 373 gears, so that also applies more torque to the rear end.
Edited by Silverado 6.2
I guess the one problem I have is that they are selling brand-new trucks with a problem and you are coming back and getting shims was put into the driveline that will obviously need replacement at some point will be prone to failure overtime and miles. Chevy has been doing this shit for years, I have had three Dodge trucks in the past five years and I have to tell you that the drivetrain is far more buttoned up then anything Chevy is putting on the road. I still have my 2006 Silverado with 140k and will drive that into the ground before I give them any money for a substandard product that has to be shimmed and rebalanced constantly.
I don't have a 4x4, and by shims do you mean the leveling kit shims? Or something different?
At first I was like, I'm taking the lift kit off asap but I honestly don't think the lift kit could cause that issues or I might be wrong. On the rear end it would be the bigger block under the leaf springs, and the front end just those plastic polymer and preload strut spacer in the front.
Mine does it around 80-90 accelerating hard only
Edited by Amuro
Exact same issue and setup level kit rearend and all except I have the 5.3.
My issue came back after a short while. Did yours? Also the shim kit they put in mine are silver almost like a cast something.
Is there an in vehicle road test that can be done to check for out of balance drive shaft? Taking up to 75 and dropping in Neutral and coast down... Does that stop the shaft from spinning?
No, the driveshaft is always spinning if the car is moving.
That would not stop the driveshaft from spinning as the driveshaft is solidly attached to the rear axle, so when the wheels spin, the driveshaft does as well.
Thanks, I am going to go for some exploration on the driveshaft issue balance and runout issue.
Just to recap my vibrations:
a light constant vibration in steering wheel, multiple tires, Road Force and balancing never clears it up not speed dependent
Highway speeds 65 to 85, vibration subtle 65 to 72, 73 worse, anything above 76 feels like the rear is hopping
When getting on it from 40 to 80 not much vibration, vibrations return on deceleration
Highway speed vibration seems to move from front to back and back to front when going up and down hills
Highway speed vibration seems more pronounced when going taking sweeping turns
Drive shaft will always spin like others have stated.
First thing I'll do is take out the drive shaft and get it inspected at a driveshaft shop that specialize in that type of work.
If that doesn't take care of the issue as I hope it does though, then the last step for me is to take off the RC 2.5 leveling lift kit and put the suspension back to factory and test drive it again, time consuming and redo the damn alignment again.
Funny, I was told by the dealer that I would have to pay them to balance my duratracs before they would move on to pooming at the driveshaft. I asked for a road force balance and they didnt know what that was.....
I feel that, I'm so disappointed I kinda wish I had gotten the Audi I was looking at. But I like trucks more
My exact situation, was looking at an Audi S3...pulled the trigger on the truck though. Dang!
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
