Guess we are all in this together! My truck has been "fixed" once already. It's doing it again about 1000 miles later. Like many, I also wish I never gotten rid of my previous truck. Between the Trans feeling like it may fall out, to water leaks inside the cab. I really am getting fed up. Worst part is that the dealer service is terrible!
Edited by 14allterrainNY
My cab had a few mystery water leaks as well. First it was the satellite antenna, then it was a pinch weld in the roof panel that had burned through the metal when it was built! I got lucky and had a tech that didn't give up. They replaced the sunroof seals, readjusted and it still leaked when it rained hard. The tech took a chance and pulled back the door seals along the roof edge, saw nothing wrong but still grabbed a hose and ran water over the roof with the seal pulled back. He noticed a little whirlpool form where water was getting through a pin whole in a pinch weld. It would take a lot of rain since it had to fill the roof panel before it would get in the cab and leak down the b pillar. Anyway, a little seam sealer on the hole and no more leak.
Edited by mdes0
Just checking is to say that the hose clamp trick worked great for me as well... Thanks!
Edited by nunyazz
A whole hole? :rolleyes:
Edited by pm26
I did the hose clamps fix on my 2014 chevy a few days ago, and just got to drive it today, and seat movement is gone, after it stayed in Tuscaloosa Chevy, dealer 3 days for their fix which was worse when I got it back than it was when I left it there, not counting the scratch they put on the right rear door, and the service manger said it looked like a real old scratch to him I ask how old he said looks to over a year, told him the truck was only 4 months old, but any way, gonna have it fixed and let small claims court take care of that, but the guy that came up with this fix should get something for this it is so easy and I'm a very old man.............just saying....
Yes, that's the risk you always take when leaving your vehicle with the dealer for some time.
While my truck was still under basic 3/36 warranty,I had some pitting on clear coated wheels and the dealer said that they would take the wheels off and leave my truck on the lift for week and half while the wheels would be shipped to a facility 200 miles away and redone. I declined to do this because I could only imagine what could happen to my truck sitting there for 10 days on a lift without wheels and all the work going on next to it.
Edited by pm26
Does this affect bench seats? Or the 40/20/40 bench seats...the one with the 3 cup holders in the middle.
Thanks
MD
Edited by DeePa
Yaaay , my new three week old Silvy needs the hose clamp fix. This is my third 2014 with the problem. If I EVER meet the designer or supplier of these seats Im gonna kick them right square in the ass. :idiot:
Thanks
MD
Yes I have bench seats and the driver seat shifts. From what I understand it affects any driver's seat with the power adjustment option.
Thanks for the info. Every once in a while a feel a slight movement, but i can never replicate it. I have tried shaking the seat, etc. and no luck. I am wondering if body weight makes the seats fail faster.
Mike
Mike
The seat adjustment settings have an effect. Mine was shifting bad before my oil change. Then apparently a Hobbit drove the truck because my seat was practically in the dashboard when I got it back. After adjusting it back to what I thought were my original settings, I haven't felt the seat shift at all and it's going on 2 weeks now.
You went through three 2014 trucks and still have problems? Maybe the forth one will be perfect. :rolleyes:
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
