My brother in law, who has the Sierra AT, with the bucket seats, also has this loose seat issue. It will b nice when a permanent fix is found!
JL83,
I am sorry to learn that you are experiencing an issue with your Silverado regarding your seat moving. I am more than happy to look into this concern for you. Private message me including your contact information, VIN, current mileage, and preferred dealership if I can be of any assistance.
Jennifer T.
GM Customer Care
I have over 5300 miles on my Silverado, no seat issue yet. Makes me wonder why some have it and other don't.
Mike
Three times now my dealer has tried to fix my seat issue along with a myriad of other problems with no luck. This last time they told me there is nothing else they can do...literally "nothing else they can do". Thank you GM! Once again you instill confidence in your consumers.
Have you all noticed there are no lights around your radio knobs too? They are there. GM can't figure out how to turn them on. See post below.
http://www.gm-trucks.com/forums/topic/152662-any-new-2014-silverado-owners-having-issues-with-their-truck/page-30?hl=%20drivers%20%20seat
I'm currently negotiating with GM for a buy back and even that is handled with the grace of a monkey trying to hump a football.
Start brushing up on your state's lemon laws. This truck is a nut filled turd.
It would be great if one of those guys who has access to the GM parts diagrams could take a look at the power bucket seat frame and see where the pivot point are. It seems to me you might be able to shim these points to take up the slop/slack, but hard to tell with the seat on there....hence the parts diagram..
Add me to the list of seat clunkers, Mines a 2014 Sierrra SLT CREW seats are leather heated and cooled power. Clunk or shift on braking acceleration at times turning into driveways etc. cant do by just wiggling something is loose. Hate to start the whole argue with the dealer thing, just got back into gm after a hiatus for 7 years hope its not a mistake. Love the truck aside from this. As its my main commuter will have to see when I can do the dealer dance. Don
Mike
It may have a lot to do with an individual's body weight. Lighter people probably experience fewer problems.
Funny guy some of us work hard for a living and if this truck isnt up to a 230lb man who can bench his own weight plus. It's hardly professional grade. Not all of us bought it to cruise the mall
  • Like 3
I wasn't thinking in that matter, I'm more inclined to think that maybe there was a manufacture change or something along those lines.
Mike
I was thinking while weight may be a large factor, that I would be interested to hear if this is something taller or shorter people are experiencing. For the most part, taller people will adjust the seat to a similar positon to other taller people, and the same for shorter people. Therefore there may be some similarity between drivers who are experiencing these issues?
I am 6' 5" and 240 and I know I tend to have the seat further back then most due to my legs.
My point being that the movement seems to be in the track and maybe if the track is fully extended/back then the track receives less support or interaction with its support brackets. I have been sitting with my seat further forward than normal and the interaction between the seat track and the track frame mounted to the floor is much greater and I havent experienced the movement yet......knock on wood?
I wanted to try and shim the space between the floor mounted track and the seat mmounted track portions to see if that helps as the next step. You can see at the front of the track that they have done just that, but I dont see the same shims at the back.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
