Hello,
I've read a lot of good information on here so I'd figured I would ask a question. I have a 2006 GMC Sierra with 288k and it is the best truck I've ever bought, however, I feel it is time to switch to a newer Sierra. I'm looking for a 2014, 2015 or 2016 Sierra 1500 with the 5.3L AWD and Crew Cab. Which model year is better as far as bugs and issues and why do you recommend it?
Thanks
2016 IMO. The MyLink/Intellilink improvements alone are worth it, and are the HID/LED headlights they went to.
Thanks for the info, I think power train wise they are the same but I'm not sure which model to get.
If you are shopping 6.2, they are 8L90 (or A8 as some refer to) transmission 2015 and up. 2014 they were 6L80 (A6). Really the only major change powertrain wise. 5.3 is going to be the 6L80 2014-2016. If you go 5.3, find one with 3.42 gears.
Thank you very much, what other rear axle ratios are available on these?
On 5.3 its 3.08, 3.42, and with NHT max trailer only its 3.73. 6.2 with the 6L80 will be 3.42 standard, 3..73 with NHT max trailer only. 6.2 and 8 speed its 3.23 standard, 3.42 with NHT max trailer.
Which ever model year you decide on, make sure you test drive it on the highway and at night as well to make sure it meets your driving and night lighting expectations.
very little practical differences between the years. I would say the best year by a very slim margin would be a '16. Since it has the newer front end but not the performance trans tuning issues of the '17, which may not be an issue at all if you never want to tune.
I personally wouldn't care what year, just go with the best deal you can find.
2014 & 2015 FTW. You get removable cup holders, red backlighting, 3 USB ports, and a 6 speed.
Seriously though, I do prefer those small differences on my truck than the newer ones. But in all honesty you're better off with a newer truck. Less bugs (mine didn't have many tbh) and you get the led/hid lights. Lots of guys have issues with aftermarket hids for some reason.
Hello,
Thanks
2016, had a 14 Silverado, and now a 16. The 16 has been a much nicer trouble free truck.
I got a great deal on a 2014 Certified Pre Owned Sierra. I have only had it 6 months but no issues as of yet and if I do encounter one then the warranty has my back. Just do your research and find the best deal. I actually flew to get this truck, it was the best deal I could find online and in person shopping.
I have those in my 16. Cup holders don't really need to be moved IMO and I've never used the USB ports in my 14 or 16. They didn't change the back lights till 17 and I guess I was one of the few to get the 6 speed with my SLT.
As for the OP I'd stick with a 15 or newer Sierra as the 14s seem to be showing their 1st model year problems. I had a 14 with no issues I just wanted a crew cab when my son was born.
Which year Sierra 1500 to buy used?
1990, if you can find a good used one, it's bulletproof.
Thanks Tim...LOL
I have 288K miles on my 2006... I'm trying to move up, not down...LOL
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
