Hey guys - Thanks for the feedback! @Mike Harding, I get tons of PMs., but will get to yours. While it feels like I am doing this full time, I don’t. :). Also have a regular full time job too :). Give me a few and will get to your PM.
1 hour ago, Mike Harding said:
Hello my name is Mike. I have a 2015 Silverado REG cab. I wont to get a console for it, I have a  jump seat there now.  went to my dealer today to order one. they said they didn't have it in the reg cab. so I'm wondering if it will even fit and how do I get it? My truck is black my interior is Jet black.. I also want to get the plug and play harness. Can someone please help me. I would greatly appreciate it. Not even sure if I'm in the right forum topic.
A center console will fit in your truck, have seen other members do it in a regular cab truck. You just need to find one and get a harness from Phil
I searched autotrader to find one in a truck I liked then used that vin and ordered from gmpartsnow
I just bought a 2018 Silverado LT with the jump seat. I love the look of this console (my 07 had the console). My question is unrelated to most of the other questions here, and I didn't see it addressed, hopefully someone can help.
The one thing I really like about the jump seat over the console from my 07 is the amount of storage (lockable at that). By switching to the much better looking console, would I be losing all that storage? Is there lockable storage? On my 2018, I use the area under the jump seat for a check book, etc, and like that it's "hidden" and lockable.
Can someone post a picture of the "inside" of the console? or are the pictures I'm seeing what you get, just a big open area?
Similar storage by the square inch its just laid out differently. There are pro and cons to both. If your handy and creative you can make more hidden storage with the full console.
I have a regular cab and yes it will fit perfectly in the existing jump seat 4 bolts. I will try to finish mine Today or Tomorrow and will post some pictures.
That would be perfect... I thank you very much..
Mike
They told me that they didn't put one in the Reg cab. So they didn't have a part number.
Wanted me to find a truck or the extented cab and get the vin number.
My truck is black with jet black interior with white stitches.
So I guess I'll have to find one that is the right color..
What color is yours?lol..
Mike
And I was wondering if all the consoles were the same size?
I sure do appreciate you talking to me. This is harder than I thot.. but its getting easier.
All are the same size in Silverado's 1500 and 2500 and the same consoles, just different color/texture trim. However, the Tahoe center console is different.
On 12/13/2017 at 10:35 PM, pgamboa said:
Jump Seat to Full Center Console Retrofit
Plug and Play Harness by PGAMBOA
For those of you looking to swap your Jump Seat to a Full Center Console, I now have a Plug and Play Harness for this upgrade!  This long awaited - PnP Harness will allow you to EASILY perform this upgrade.  NO cutting or splicing needed!
Center Console - Plug and Play Harness is $125 Shipped to lower 48.  For Alaska, Hawaii, and Canada, please PM me for a quote.
Since there are several versions and configurations of center consoles and truck trim levels, I feel that I have covered a majority of the configurations that are out there.  There will be several assumptions on the ability to perform this upgrade and I’ll try to be as detailed and comprehensive as possible.
Please see the different USB Cable configuration diagrams at the end.
Assumptions:
- 2014-2015 Center Consoles will have different USB Cable requirements than 2016-2017 AND will have different USB Hubs.  The PnP Harness should be compatible, but you MUST verify the connector under the passenger AND the front of the console!  Since this is a custom product, there will be NO REFUNDS on it.
- Center Console MUST have its factory harness intact and not modified.
- Connection under the Passenger Seat AND Front of Center Console must look exactly like the diagram.  There is a variant X314 Connector under the seat, so yours MUST match in order for this harness to adapt.
- Additional GM USB Cables must be purchased separately (based on your console year) to get USB Hubs functional.
- Wireless Charging - Wireless Charging became available on 2016 and 2017 consoles.  If you are looking at adding a Wireless Charging Lid to a 2014-2015 Console, please PM me for requirements.  Also, there are known issues with 2016/2017 Consoles with the Wireless Lid and charging iPhone 8 and iPhone X Phones.  There are workarounds for this that require some form of modification to the charging module.  You can also swap the module for a 2018 Module that DOES charge iPhone 8 and iPhone X phones.  Please PM me for questions on specifics.
- Your truck MUST have an existing 110V AC Outlet AND (1) - 12V DC Cigarette Lighter Plug as you will be reusing those.  My PnP Harness DOES NOT add the 110V AC Outlet if you don’t already have it.  However, I CAN add an additional 12V DC Outlet connection if needed.
- USB Cable connections will come from your HMI (Behind the Glove Box).  You MUST verify that you have the USB Ports available, otherwise, your USB Hubs will not work correctly.
- This PnP harness DOES NOT add any Car Play, Apple Play, or Android Play functionality.  If your truck did not already come with it, you will not gain it.
With this PnP Harness, you ***should*** have ALL the components in your console functional.
Those options include:
Front of the Console:
  • Front - Left USB Hub (Dual USB - 2016/2017or Triple USB Hub 2014/2015 - Uses my Plug and Harness AND a USB Cable from the HMI
  • Front - Left 12V DC Cigarette Lighter Outlet - Uses existing connections (truck must be equipped.  If not, I can custom add this if needed)
  • Front - Right 12V DC Cigarette Lighter Outlet -  Uses my Plug and Play Harness
  • Front - Right 110V AC Outlet - Uses existing connections (truck must be equipped)
Inside Storage Compartment:
  • Inside - Left 12V DC Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Inside - Right USB Hub - Uses my Plug and Play Harness plugged in the front main 42-Way Connector and USB Cable
  • Inside - LED Lamp - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
  • Wireless Charging Lid (2016-2017 only) - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
Rear of the Console:
  • 12V DC - Cigarette Lighter Outlet - Uses my Plug and Play Harness plugged into the front main 42-Way Connector
THERE IS A LOT TO CONSUME HERE, SO PLEASE PM IF YOU HAVE QUESTIONS ON THIS.  I WANT ENSURE THAT YOU UNDERSTAND ALL THE REQUIREMENT FOR THIS RETROFIT BEFORE PURCHASING.
16-Pin - Plug and Play Harness
23-Pin - Plug and Play Harness
Pgamboa I have a 16 pin and I want to order the PnP harness from you. PayPal?
Also I can supply new door harnesses if you are interested.
Mike
Here you go. It fit perfectly but you need to remove the seat for easy access.
As I removed the seat I will take this opportunity change seat cover :D
A big thank you @pgamboa for his fantastic service and help.
Hey Phill We can do this just watched your video a shit load of times ,
I think i don't need a hmi box , we just come from under seat (usb) to input side of front double usb , come out from out going side to brown plug on front that feeds the console box , that picture i sent you of my  (vais xm)  plugged directley under seat works fine. still have car play ,
So i should order those usb cables unless you have them
So i'll just need your power up wireing and the upgrade plug for wireless gharging pad ,
