8 hours ago, polarys425 said:
What parts numbers is that setup?
This is for a cocoa center console with silver trim.  2018 model with wireless charging lid
Edited by Rfg14silverado
Added info
Keep in mind, there will be many part #s for different color options.
- Black Console vs Cocoa Dune
- Black Leather, White stitchin, red stitching etc.
-Upper tray panel will have like 8-9 different trim color pieces.
Yeah, finding part numbers seems to be hit and miss. He did state that his is cocoa, and I need black. Even google searching doesn't turn up much, as it always shows me a cocoa result even if I search for black. I'd go to the dealer, but I feel sure it's cheaper to order from one of the websites that sell GM parts.
I'd like to have the '18 console in black, with wireless charging, and whatever would have been put in a Z71 trim if any of it was trimmed for a Z71.
This is the list that someone here provided some time ago. It is apparently for Black, 2018, with wireless charging. I separated and grouped the options based on data I’ve gathered over the last few months.
Hope this helps.
84288042 - Console (Black with Synthesis Trim) - $411.32
Chose the trim of your choice:
84092079 - Upper Tray (Reverse Tartan) - $144.64
84092080 - Upper Tray (Synthesis) - 138.86
Choose the trim of your choice:
23467516 - Side Trim (Black) - $24.01
23467517 - Side Trim (Cocoa) - $23.54
22817347 - Side Trim (Black) - $52.27
22817348 - Side Trim (Cocoa) - $52.27
22776807- Bracket - $14.92
11609982 - Bolts (qty. 2) - $5.96
USB Cables - You only need two, but most get all 3 just in case of a last minute configuration change.
84023215 - $24.80 (Green to Grey)
84022323 - $22.32 (Black to Brown)
19119050 - $22.90 (Black to Grey)
Subtotal $723.02
Shipping $74.31
Hope this helps.
Subtotal $723.02
Shipping $74.31
HUGE help. Confirms the 84288042 number that I did find, as none of the site show any color details, etc. The Z71 use the reverse tartan, I wonder if there is a separate console number for that to match the upper tray? Any details on the USB cables? Also, the 84023215 usb cable isn't found when I search for it...
Thanks for being a HUGE help... I will be ordering your cable when I sort out my parts order and pull the trigger.
The upper trays are separate (from my observations) from the console itself.
The Reverse Tartan upper tray will Have the side trim piece as Reverse Tartan and will match the reverse Tartan trim panels on the doors of Z71.
I don’t know if any other differences on the console itself, besides, maybe the cup holder color/outlining.
On 8/5/2018 at 10:15 AM, pgamboa said:
I’d like to correct some info on fitment. I had the opportunity to help a local member who has a 2500, Signal Cab, Long Bed Truck. The fitment was ok. We were able to get the console bolted in... BUT, there is a gap up at the front.
My harness build still worked fine, but you can see a small gap up front. I am unsure if there is a center console that is specific to 2500s that might just slightly longer. We also check if there was any play in the 15mm bolts... not enough to close the gap.
Here are some pics
I have recently purchased a 2018 regular cab short box 2wd and would like to install one of these consoles. Has anyone else had this issue in this configuration?
Will fit all day long. It was just the 2500 HD truck that had a small gap between the front of the console and the dash.
Cool, thank you Mr. Gamboa! Will be contacting you soon.
I finally completed my console on my truck gmc sierra 3500 hd sle regular cab.
Thank you phil
Look for more installations ?
Wow so the 3500 HD regular cab fits just fine, too then? I wonder what the deal was with that one 2500 HD?
Same cab to 1500 and 2500hd
It well fit perfectly.
8 minutes ago, Osirus said:
Someone did a 2500 HD recently and had a 1/2" gap between the console and dash, seems to be the only instance of this happening:
https://www.gm-trucks.com/forums/topic/207916-2014-k2xx-center-console-swap-retrofit-plug-and-play-harness/?do=findComment&comment=2136958
It should be 3 brackets
2 uner the console
1 on the dash
The one on the dash is responsible for hold the console up
BIG …..   Shout out to Phil!      :thumbs:
Thanks So much I received my harness for my console swap today, plug and play as you told me!  You tube  video is Awesome !!!:D
This is great !!!!!!:)
so glad I found your video on you tube !
If your thinking about swapping your jump seat for console you need to PM  Phil !!!!!
Thanks Again
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
