New 2019 Silverado Info In One Month - What's On Your Wish List?
John Goreham
12-15-2017
The Detroit Free Press predicts that the Detroit Auto Show in mid-January will be "Dominated by trucks." The rumor is that Chevy may debut the 2019 Silverado at this show, or at least offer a hint of what is to come. Ram is expected to show off its new truck at the show. 2017 was a mixed year of news for the truck world. Ford seemed to win all the awards, and even with a couple hurricanes to spur sales, the overall outcome is likely to be a slight decline from the highs of 2016.
Cargo areas are all the buzz right now. There are unsubstantiated reports that GM may use carbon fiber, or some type of non-metallic bed, in its upcoming trucks. Ram may have a novel tailgate. With the new trucks about to break cover, we'd like to ask what would be on your wish list for a 2019 Silverado . Post your wish in the comments below.
  • Replies 42
Same thing that's always on my wish list, a base RCSB with a 6.2. But it'll never happen, because it would be too fun and GM's bean counters are a bunch of halfwits.
Being able to actually customize a truck the way I want instead of having to get 10 things in a package I don't want, just to get the 1 I do want.
X100000!!....Most of those packages are full of crap that is undesirable to me ...Why a sliding rear window is not a stand alone option on ALL trim levels is beyond me
I have a feeling some folks in Texas might get to see something today...
Quote
Tomorrow, nearly 1,000 people will join us in Dallas to celebrate a milestone 100 years in the making -- the Chevy Truck Centennial.
To mark this historic event, we invited some of our most loyal and enthusiastic truck owners to join us in Texas to sample our award-winning product lineup, to hear from one of our most outspoken Chevy fans – Dale Earnhardt Jr., and to see some of the most significant Chevy trucks from the last 100 years. Of course, we also have a surprise or two in store to make the day even more memorable.
We knew we couldn't celebrate without our customers because they have played such an important role in our success over the last 100 years and we are thrilled that so many of them will be joining us for this special event.
Crewcab Std Bed Z71 color TBD
Few options that would 100% sway my decision going from my 2010 to a new one as soon as I can
- HUD
- Rear Flat Floor
- Rear center seat head rest
- 6.2 Engine available
I would actually trade my ZO6 for one of these!
Well, can't say I'm impressed with it. Don't hate it, but not in love with it either.
It does appear to have some more ground clearance, so they listened there. But the headlights are F150ish, I'll need to see more to form a final opinion.
well at least they finally rounded out the wheel arches and got away from the squared off ones.
I like the front end the more I look at it, and the mirrors. Not sure on the body line on the front fender, and I was one of the few that like the squared off wheel wells.
I see they are still using rancho shocks, that's unfortunate...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
