On 4/25/2018 at 9:27 PM, WesternMike said:
115,000 on my 14 with not a single problem, like not one issue at all with this truck.
Mobi 1 every 5k
91 octane since purchase
Diablo Trinity with AFM and DoD disabled
91 octane tune
Super 10 muffler
Cold air Intake
Run the sea foam every oil change or two as well, will only help! YouTube the process.
If we look after these trucks like we do our bodies.. they will last.
just wondering but why mobile 1? why not ac delco since it’s recommended on there owners book? just wondering since many people say mobile 1 and some say ac delco...
ACDelco oil is not always easy to purchase.  Not as simple of going to Walmart or even the local auto parts store.  I had to hunt it down and drive a ways to get it.  Thus far it seems to be better than plain Mobil 1 synthetic.
1 hour ago, HeySkippyDog said:
That is for the LS engines. GM stopped building AFM LS engines with the 2013.
2014 for the SUVs.
I did a afm/dod delete on my 2014 due to  lifter collapse when I when to race a old school Chevy ? the first week I bought my truck costed me a good 1500$ due to parts and labor just for the non  afm cam and kit, another 320$ for the y-pipe that messed up due to driving with with no tune, and 140$ for the tune, but now I kinda get ok gas mileage Ig for a truck better then my mothers Dodge Ram with the hemi!!! Glad I don’t have to worry about the lifter collapsing again or the v4 mode kicking in
On 4/25/2018 at 2:46 PM, Doublebase said:
I don't know much about this system, how it operates, the stress that is placed on the lifters during cylinder deactivation. How common is this failure?
The possibility exists. No one can tell you what the odds are. Its a fundamental flaw in the way the design of the engine, with regards to how it has been modified to meet EPA requirements. Until GM comes up with a new design, this won't change. People are saying that GM  have corrected a lot of the AFM issues, but they don't seem to ever site sources for this. As far as I can tell, GM has not published a media release on this issue other than the dealer bulletin. There has been no released description as to what exactly they have done to make the lifters more reliable, so I have to assume nothing has changed since the early models. GM doesn't release their reliability or warranty statistics, so anyone saying that "fewer people are having problems with the newer models" have no basis for knowing if that is true.
The manufacturer of the lifters apparently got fed up with GM sending back faulty lifters and blamed the design of the oil system. GM hasn't really responded to this in any official way.
The repair basically requires a rebuild of your engine. You technically can replace just the lifter that failed, but you are better off changing out the cam too since it has likely been damaged or scored. When a metal part is scored, you have to ask where the metal shavings went. They don't just disappear. They go further into your engine. If this repair is under warranty, GM often won't investigate this far. They just replace the broken lifter and stop at that.
Given how extensive the damage can be when the lifters fail, I wouldn't continue to run a truck following the failure. I'd generally consider it to be an instant trade-in.
On 7/9/2019 at 4:30 PM, 3tspapat said:
So of all of the GMs produced with AFM and is currently out on the road, what is the percentage of ones that have failed so far?
Dunno.  And GM sure as hell isn't saying.  It's a miracle they haven't had a class action lawsuit on this.  But the actual number is high enough that the Service Manager at my GM dealer says there are 2 types of DOD/AFM/whatever-they're-calling-them-this-week vehicles: 1)  Those vehicles that already have AFM problems, and 2) Those vehicles that will have AFM problems.  He only drives Toyotas, by the way.  (And I don't like Toyotas.)  They have one full time Technician that just does engine teardowns for AFM fixes--that's all he does, every day, and he has gotten really good and fast at it, but even with that, sometimes they have to have other Techs assist--there are that many problems.
Edited by MaverickZ71
On 4/25/2018 at 4:46 PM, Doublebase said:
I don't know much about this system, how it operates, the stress that is placed on the lifters during cylinder deactivation. How common is this failure? Been watching some YouTube videos on the repair and it's very labor intensive...heads have to come off, etc. I see that you can buy the entire kit (lifters, gaskets) for around $500.
Have a friend that told me...just change your oil, you'll be fine. The number one cause of this failure is neglected maintenance. That true? Or is it an inherited problem with the design of the system?
The system came out in 2007, there must be some improvements made to it since then, no?
I must say that the AFM is allowing me to get some excellent fuel economy out of a full size truck.
So is this a common problem, or are there people with 200,000 on these trucks that never had an issue with it?
Unfortunately, it has been an all-too-common problem for many of us.
The most common 'fixes' are:
1) Use a good quality full-synthetic Dexos-rated engine oil in the correct viscosity and quantity, and a good oil filter that's not too restrictive.  GM's own Dexos oil, Shell Rotella Gas Truck, and AMS oil seem to be the top-rated oils now.  Consider changing the oil more often than the Oil Life Monitor indicates.
2)  Consider installing an oil catch can into your PCV system.
3)  Turn off AFM via a Range V8 module or PCM tune as soon as possible.  Some AFM lifters seem to have a short lifespan, and the more cycles of 8-cylinder mode to less-than-8-cylinder-mode that you subject them to, the more likely they are to fail.
4)  Some have even gone so far as to have their engines torn down and rebuilt with an AFM-delete kit from Texas Speed (or such).
5)  GM's own documents suggested that Generation 1 AFM saved about an average of 7% on fuel economy.  But many of us who deactivated AFM noticed little to no difference in our fuel economy, and some have reported better drivability (no surging with AFM kicking in/out, better transmission shifting, better sounding aftermarket exhaust) with AFM turned off.
Deal of the century for ACDelco oil:  https://www.rockauto.com/en/moreinfo.php?pk=9721864&jsn=254
Well 33,000 miles later and everything seems ok (averaging 24.5 mpg over the life of the vehicle). Change the oil every 5,000 miles, no mods aside from a catch can. We'll see how it goes...hoping for the best but won't be shocked if/when it happens.
Reading through a couple of posts on here regarding dealer feedback...I have a totally different experience of feedback. When I ask about the lifter collapse they tell me it's a non issue, that people complain about the "feeling" of when it switches between V4/V/8, but as far as repairs, it doesn't seem to be a major issue where I am. I mean they may just be lying to me (talked to 3 different dealers).
And i do work with 6 different people that own these trucks, none of them have had an issue yet (although one does experience bad oil consumption). And one of them has over 200,000 miles now. Personally on mine, I do experience some oil use...probably 1/2-3/4 a quart over 5,000 miles.
You might be surprised how many dealers out there don't even know an issue with AFM and lifter collapse exists until they get one for the first time.
I don’t think GM tells the dealer anything. In 1993 I read an article in hot rod mag about the impala ss. I went to the dealership to put down a deposit. They laughed and said go to auction and buy a police cruiser, caprice. 6 months later I’m driving one, all they said was oops.
2015 Silverado High Country 6.2 60,000 miles. Went to Tennessee on Friday the 12th for vacation. Pulled 2 waverunners down. Came back yesterday with a rental car that I had to pay for. Collapsed lifter. Been a Gm man for 30 years. Not happy. Truck will be there for a couple of weeks. Then go back down from Illinois and get truck and waverunners. VERY Inconvenient. I'm pretty sure me and Gm broke up.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
