Just out of curiosity with the stock HIDs I get flashed for having my brights on ALOT. I am guessing its due to the lift/tires. Has anyone adjusted their headlights down after their kit was installed? I am not sure if this would help or make it worse? Thoughts?
That’s 100% mandatory after you lift the truck especially if you only change the ride height in the front.
There’s info in your manual about how to verify you have the headlights set properly
Thank you sir! Got it done when I was at the dealer getting the oil changed today. I will have to check on if it is correct after this snow event.
Saw your jam handles video, congrats on the new truck!
When you get your high beams screwed back down where they belong, you’ll be a lot happier with the pattern as well.
Ive had my eibach kit for about a week and I really like it. I went with the new springs and I got some UCAs from kryptonite to replace the stamped steel ones. Currently sitting at 2.5in in the front and its nice and level. The angles look pretty good to me as well
02d9ae20171626ff7db0c49f0fe67c8a.jpgeb0ac4bab27ca4b14f61bb186b23e259.jpg77d6f5f2ac87790651ec3883a976980b.jpgf6d134c9ebdf3ac8d297f89188654444.jpg
Sent from my Pixel 2 XL using Tapatalk
Got my kit plus Cognito UCA's waiting to go on.  I was quoted 4 hours labor @ $105 per to do the install by a local shop (just for the kit and arms, that doesn't include alignment and such).  Sounded pretty reasonable to me, I live in a large metro area so I don't expect to see the lowest labor rates anyway.  What do you guys think?
Kryptonitw??!! Baller!!!
Install looks great.
On 3/2/2020 at 7:55 PM, DysfunctionalVeteran12 said:
Hopefully this thread has not died. But I'm curious as to if anyone has done this at the highest or thinks this kit could benefit from diff drop and uca's to get the angles closer to factory? Or am I running down the wrong path with this?
I am currently at 2.5 and am going to do ucas and diff drop and go up to the 3.2 eventually. solid plan imo
Thanks man!
@techsan15
are those wheels -24 offset? can you snap a pic at full lock .
I've got 295-55 with 20x10 -19 wheels and I've posted a thread about going a bit higher to fix rubbing issues I have with Bilstein 5100 at heighest setting. think this kit and some new ucas might be just enough after seeing your truck
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
