Interesting Owner Survey Results Prove How Much Americans Love Trucks
John Goreham
9-26-2018
A new poll of truck owners commissioned by GM and Done by Harris Polls confirms what we GM-Trucks.com members already knew - Americans love trucks. Here are some highlights of the GM / Harris survey:
Is Your Trucked Named Betsy?
According to the survey, 27% of U.S. pickup truck drivers love their truck so much that they name it. The most common pickup truck name in America is Betsy. The second most popular truck name is along the lines of "Big Red"
Do You Help People With Your Truck?
89% of U.S. pickup drivers have used their pickup truck to help others.
33% have helped tow a friend or family’s car.
33% have used their pickup truck to support a school, community or charitable cause.
Is Your Truck a Family Member?
57% of U.S. pickup drivers consider their pickup truck a part of the family.
45% plan on passing their pickup truck down to a child or loved one.
38% say they love their pickup truck more than any other object they own.
60% say they “can’t live without” their pickup truck.
Have You Marked Some Life Milestones In Your Truck -Let's Keep This One PG-13
26% learned how to drive in a pickup truck.
10% have brought a baby home from the hospital in a pickup truck.
9% had their first kiss in a pickup truck.
Is Your Truck A Magnet?
38% think driving a pickup truck makes them more attractive.
37% believe driving a pickup truck makes them more popular.
Feel free to weigh in on the poll in the comments below. We know this is sort of marketing fluff, but it rings true.
Handiest thing ever.  Couldn't imagine not having one.  The ease and convenience of 6 feet of open cargo space is perfect.  Mines got a name as well.  I learned to drive in one and I was actually brought home in one.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
