I don't understand why so many of you paid for trail bosses and AT4 trucks only to remove and stick 6 inch lift on em or even add to stock lift...…..why not just buy a standard 4x4 in any trim and than do a lift?......would save a lot of money I would think
those models were easily 10k plus more than my RST...…so what am I missing?
The prestige and a sticker? Personally my RST is nicer than most trail boss trucks I see. Those black bumpers are atrocious.
I can run a 4in lift, UCA,s with KING 2.5 coilovers and rears for way less than TB LT, which is what I would basically have...….and with much better suspension....I had fabtech lift b4 and suspension was shit, was along time ago though
idk, just thought I was missing something
would rather get LTZ 6.2l and do the KING setup....
Edited by Dunn
Guest citrusbb
I just had a 3” Fabtech lift installed on my ‘19 High Country. Stock 20’s with Michelin Defender 295/65-R20’s (35”). These are a little narrower tire and gives the truck a unique tall, somewhat skinny look. I started with that look in 1977 with an F-150 and 9:00x16 Non-Directional Military tires. I’ve run Michelin’s for many years, last set on an F-150 went 89,000 miles and still had a little left. Love this truck.
Silverado is tricky truck to get lookin good with lifts and even stock, not a fan of chubby look I see so many of....I probably go for more of stock look just bit taller same for tires.......looks good
I couldn’t agree more with you I’m a fan of the stock look. Reason being they just look out of form/shape when you lift them. Granted the right lift tire setup would def make a diff. Now it just seems like a contest higher then the next guy and the whole trend with tires hanging 67 feet out of the wheel wells is just nonsense.
On 10/3/2019 at 11:32 AM, C530F said:
3 inch rough country lift
Toyo MT 285/60/20 (33.5)
no rubbing no trimming
I want to get the RC Vertex coil overs but I am on a 6in BDS lift. Would anyone know why they would not fit or align correctly?
The RC 6in kit with the Vertex coil overs does not show new UCAs just knuckls.
Did they release them for these trucks yet? I’ve only found them for the legacy body style. Try chatting with them during business hours, they’re usually easy to reach for tech support. I also have the BDS 6” and I’ve been waiting for a compatible coilover that I don’t have to custom order.
They released them with the 6in RC kit for 19s. It has them as an option to add.
https://www.roughcountry.com/gm-suspension-lift-kit-22930c.html
RC coilovers on a BDS kit?.....blasphemy!  [emoji23]
Contact BDS/Sport Truck USA and get the matching Fox coilovers and Fox 2.0 rears to go with your kit.
Exactly!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
