    Hey guys and gals I was hoping y’all could answer a question of mine. I currently own a 2019 Silverado trail boss with the 5.3 and 6 speed transmission. A mechanic told me the transmission is a ticking time bomb if I do any performance mods. Such as a cam swap and tune. So I explained my plan for the future. Cold air intake, flow master exhaust, headers, tune and cam swap. He said if I do any of the big changes to the engine the tranny may go out. The reason why is because the stock transmission was only made to handle the stock HP and TQ. Have any of y’all had an issue like this after some big performance mods?
I think you'll be OK with bolt ons and a cam. Any forced induction, then I'd consider tranny upgrades.
Sent from my SM-N975U using Tapatalk
Sounds like he’s full of shit.
The 6L80E is a 3/4 ton spec trans by any old measure. GM just finally learned from 25 or so years of 700R4/4L60E/4L65E/4L70E mediocrity to just upgrade to a stronger transmission from the start.
If you were talking cam, heads, blower or turbo, etc you might eventually get to where you’re stressing things with hundreds of additional horsepower but what you’ve listed won’t even be 100hp. You’ll be fine.
The key is the calibration tune with adding more power. People have been adding superchargers to stock 6L80e's for years without issues and those add well over 100 horsepower and torque to the rear wheels.
Sadly not being able to tune these new trucks has put a stop to any mods that add any real power.
   Yeah he was kinda odd and I didn’t think GM would make a something so weak that if you add like 50 HP the damn tranny would break. He was most def a ford lover not trying to be biased. I think all brands have pros and cons I’ve driven all the big 3. But he couldn’t stop talking about how ford makes the strongest Transmissions. I will say this though after driving the big 3 I feel like GM is my favorite so far.
Im almost positive the 6L80E was originally offered with the 6.2L V8 when it came out, around 2012 if I recall, before the 8 and 10 speeds showed up. The engine can definitely handle at least 400hp. From what I've read, some hot rodders even use it even. It may be a little rough around the edges, mine rough shifted every once in a while, but I think they're pretty strong. If you dont have the tow package with the trans cooler maybe look into that though and keep an eye on temps if towing/fully loaded. Mine ran a bit hot but I heard that's normal too.
Im in a new 2019 elevation with the 8 speed now, and I'll be very curious to see how it holds up. I've heard some guys on here are having issues with it but so far its running cooler and pretty smooth.
The 6 speed is tried and true. It can take a ton of power without issue. Find a new mechanic because if he doesn’t know this, I wouldn’t trust him with anything else.
I had mine rebuilt at 165k, but I was expecting it to go a lot sooner with how this truck has been used/driven. I'll also shamefully admit that I did not change the fluid like I planned to between 75 and 125k. The grenade is probably more my fault for bad maintenance, not overall abuse. With that being said, it's a stout trans!
Because we all love facts, the 6L80e came out in 2007 with the new body style denali trucks, both the Sierra and Yukon models.
The corvette also got that transmission in like 2006-2007 time frame too.
The calibration changes and minor design changes over the years have made it a good transmission.
While you are talking facts, the 5.3L and 6 speed in the trailboss is the previous gen engine and trans in the new body.  So, you CAN tune this...  Unlike the newer engines with the 8 speed and 10 speed transmissions which have the locked down computer.
 He may have been smoking crack if he believes Ford makes a good transmission... Out of all the Fords I have had experience with, the trans was always the weak link.
Keep in mind Ford and GM collaborated on the new 10spd... Or was that the 8spd? Gotta have some faith if it's in our trucks!
It was the 10 speed.  Ford and Chev now running the same transmissions!
Can you show me a calibration file for one then?
The motor/trans may be a carry over but as far as I know the computer is not. If it was then HP Tuners would have come out with support for that truck last year shortly after the trucks rolled off the assembly line. I've been waiting a long time to hear or see anything for support on the T1 trucks but nothing so far.
Not trying to argue or sound mad/mean in this post but until I see proof, it can't be tuned.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
