Have you brought it to the dealer ?
Yeah, haven't had time to go back again. They road forced the tires and it helped for about 10 days, then it came back like it never disappeared
so....my truck, 2014 Silverado, double cab, 5.3, 3.42 rear z71 - vibe issues on highway - been to the dealer many many times, changed shaft - changed tires - changed shocks - then shimmed and changed pinion/shaft angle - ... changing the shaft angle helped with the highway vibe, but created a launch vibe - and it was pretty bad( under a heavy foot) - keys would rattle against the column. even worse with a load on the hitch - since im not actually on the highway much I asked a different dealer to put it back " to stock" although the original dealer who shimmed it said the were shimming it to put it " in spec" and they were big shims - so...... launch vibe gone - highway vibe back - and noticed something - at 40 mph or so I have another vibe - a vibe I thought was v4 drone( was there when I originally bought it) - but obviously its not, cause it didn't do it the whole time I was shimmed - and now its back - some seem to be fixed with certain things- but think mine is a drivetrain alignment problem - like a cross member is off a hair from the trans or engine - just wont seem to line up - my 2 cents and experience -
Did you talk to the dealer about a buy back ?
It has been discussed but not pursued. There is nothing else even close to it on the market. I am just hoping for a fix.
Should have did a little more research before buying this truck but hopefully Chevy can fix it. Going to drop it off today.
I’ve driven the truck approximately 1000 miles on all types of roads. From 40 to 55 the truck resonates (vibrates), especially when decelerating, and going downhill. The more you drive (warn up the vehicle) the worse the vibration seems to get. I can feel it mostly through the steering wheel but can see the dash and center console vibrating in the truck when it’s really bad. I say resonate because it doesn’t seem to be the tires although I really can’t tell. Never had tires vibrate like this before. When driving highway speeds 60 to 75 the vibration is less noticeable (tolerable) but still happening. Almost seems like the driveshaft is out of balance or a bearing is going bad.
I've read through several reples and different sites has there been any specific cause for this problem or is it different for every truck?
2014 Chevrolet Silverado Z71, LT Extended Cab, 5.3L, 7k miles
They can fix it or buy it back if they can't , but only if you are persistent enough to force them to do it.
Wow, how many posts and still no cure, I'm raising the white flag. GM doesn't need my future business.
I am pretty sure mine is fixed. Take a look at my last post detailing the repair.
I have put on 250 miles since Thursday and will put on another 200 tonight.
If these trucks are so sensitive to tires, what's gonna happen when you need another set and have to keep going back for RF balacing? Or is it just because the dealers/ manufacturer gets second rate tires on the cheap?
I want some Michelin AT LTX tires or BFG KO2. The only way I would buy these tires now is if I had a second set of rims. There is no way in hell I would swap them out at this point.
There was no preload on my pinion and I think that was the main issue. I would suspect that the rear differential machine that sets these up from the factory is messing up in production. Not only was my preload wrong, they also used the wrong shim behind the pinion bearing. I highly doubt that these are done by hand anymore.
The guy that setup my rearend at the local dealer has been doing this for 25 years. You don't just throw in a ring and pinion. It is a very precise process. I set up two 12 bolts for my chevelle with an old man that had setup 9" ford and 12 bolts for years. Only after about taking the carrier out about 10 times did I get the pinion depth, pattern, pinion preload and carrier preload set right. (on the 12 bolts, not in my 2014 sierra.) The process had to be very similar though.
My point is if you don't get a seasoned vereran resetting up your rear differencial at the gm dealer, it could very easily be messed up.
Edited by OmahaBen
Oh yeah, that's one thing I wouldn't mess with is setting up a rear end without an expert involved. I just pay the 400 an axle for my mechanic at my off road shop to do it
For the couple guys that have theirs fixed, mark your tire and wheel at each one. Mine was "fixed" on Thursday and I marked mine. After the ride home and towing the boat, I have one tire that has slipped almost 10" on the rim, and another just over an inch. Both rear tires. Can't believe how much it slipped.
I'm gonna mark mine before I go into work tomorrow and drive aggressive on the way to work, see if they move. Maybe the wheels are just a tad too out of spec to keep the tires from slipping on them.
Maybe it's just all this raw GM power I'm putting down... lol
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
