Here is an interesting read that I found for frame beaming for older chevys, note the lower RFB that GM is specifying.
Boys and girls, the symptoms are very similar to what we are experiencing.
This PI was superseded to add additional info about an oily film on the new mounts. Please discard PIT3009H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models.
Recommendation/Instructions:
The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following:
  1. Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible.
  2. Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate.
Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide:
P-Metric tires (2wd 1500) 12 lbs or less
P-Metric tires (all others) 24 lbs or less
LT-tires 30 lbs or less
If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reduce this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models.
FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS.
New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount.
Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue.
Upper Mount 25791031 Qty 2
Lower Mount 25791032 Qty 2
Washer 15854745 Qty 2 (if needed)
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
can you post the actual link, those wont work
Hello Taco? You mean, hello Pearl Harbor!
Sayonara- English translation = C-ya!
Toyota (specifically Tundra) is far more American than GM, as FogDucker says below. I believe the Tundra Crew Cabs are even higher than 60% American though.
Last Night I bought a preowned GMC Sierra 1500 and today I noticed the rear left part of the truck vibrates. I was going to take it in to the dealer tomorrow. I have the remaining balance of the warranty transferred.
What should I tell the dealership tomorrow?
I agree with Severado, bring it back and say you changed your mind. get rid of that POS
The Tacoma has more US/Canadian content than the Silverado/Sierra. 60% vs 45%, respectively.
http://www.edmunds.com/car-reviews/top-10/top-10-most-american-trucks-for-2015.html
Buying American isn't what it used to be.
I believe the crew cabs have even more American Parts and Assembly
First post here. Long story short, I've been following this thread for about 6 months, as I've got a shaker. Dealer does the usual, tires tires tires. Today I removed the rear drive shaft, put a bag over the transfer case output to catch most of the fluid that I knew it would sling, drove a couple of miles at the worst speeds for my vibration (45 and 65), and observed the vibration to be completely absent with the rear drive shaft removed.
I just finished refilling my transfer case, and am now thinking about where to go next with what I'm telling the dealer. I'm thinking it might be related to pinion angle.
Drive it into a ditch and have your insurance buy you something that actually works lol... seriously though, Pinion angle has been brought up alot, I don't remember anything specific about results from messing with it though.
Edited by Jesse D
Could be. But it could also be driveshaft or the differential.
Hopefully you have a good dealer that will work with you.
Sent from my VS990 using Tapatalk
Well after 6 months my ordered Sierra arrived to replace my second vibrator, interior color wrong, sun roof that was not ordered, spray in box liner which wasn't ordered, sticker $2,000 higher then the order sheet. And, you guessed it, vibrates worse then the POS I have now. Dealing with 2 Ford dealers and with a little luck will be rid of GMC and their POS trucks for the rest of my life in just a few days. UnFing believable, 3 in a row.
sorry man, thats terrible
Traded my POS today, officially a Ford owner, good luck everyone, and if anyone from GM ever reads these posts. Thanks For Nothing. I have made sure my 3 sons know all about the great GM support I had over the 13 months it took for me to finally bite the bullet and dump the pig.
Mine is being traded in tomorrow. 2016 Acadia. I don't hate the brand but I sure as hell not chancing another truck until this issue is fixed. These are going to end up being useless in a few years once people start really complaining.
Your box is tuff...but she sure vibrates ;)
Edited by KingstonMom1976
Curly Bill in Tombstone; "bye"
Why are you posting this in here. This is for shake and vib issues.
NOW I can unfortunately say I'm posting in the "correct" thread.
Brand new 2016 Silverado crew cab, short box, 2wd, 5.3L gas, with 20's.
Took it on a 1200 mile trip w/200 miles on it at home and our water bottles and human cargo were shaking at hwy speeds. Also, the electronic steering assist went out a few times at around 78mph. I'm guessing the vibrations were just too much for the steering computer to handle at those speeds. Just a guess.
We are at our vacation destination so I took it to a local dealer who did the usual checks for the steering issue and also road force balanced the tires. Took it out today for only a short ride at 75-80 and the vibration is still present although not as bad as before.
I'll be monitoring everything on our trip home and taking it in if it isn't to our liking.
I've got video of the vibrations as well as pictures of the power steering going out. Crazy stuff and I sure wish I'd have discovered this thread before purchasing.
Short video at hwy speed: https://youtu.be/bLdThKzOVzM
Picture of the steering problem (the camera "couldn't" take a clear picture because of the vibration) just FYI:
Edited by OmniCamaro
Wow that really sucks! Especially the steering.
I wanted to post this awhile ago so you guys can compare vibrations. I took the following video in my wife's Lexus at around 75mph. This is what your water bottles should look like at highway speeds:
My truck: https://youtu.be/-_l-ShqMLOA
For what it's worth I don't think my truck has a vibe problem, you decide.
Btw my truck MSRPs for about 3 grand more...
Edited by dave07
Maybe it's chararistic of the new steel in the frames. An old timer friend of mine been test driving trucks recently. He seems to think its the materials being used. He test drove dodge and Chevy gmc. And thinks the ride is horrible compared to old trucks. Dodge the worse he said.
If it's not shaking it vibrating he says.
After hearing his story I told him of our trucks and this thread.
Hopefully the new US made crew will have no more issues!
6/3 - I get a call from dealer stating that after the last pico scope test GM wanted me to take my level kit off before they can proceed any further than tire diagnostic.
Annoying but alright, I'll play along. I took it off that weekend.
6/7 - Drop it off again. Gm - We're gonna pico it again oh and there's an engineer that will be here Friday (6/10) to look at yours and another truck with similar issues.
6/13 - We are waiting on a tool from GM for the balance machine that is hub mount rather than the traditional cone mount. Will re-pico after the balancing of tires is complete. Oh an the engineer never got a chance to look at your truck.
You've got to me !Q$#^%$ kidding me. You've had it a week and have done nothing.
GM has replaced 3 of my 4 original tires, swapped two more complete set of tires of different brand/sizes and have balanced tires I believe a total of 8 times now. It's been at the dealer a total of 36 days from purchase focusing mainly on tire analysis.
IT'S NOT THE @#$%%^$# TIRES.
What is scary is the balancing machine did not have a tool to balance hub centric....
I think you should have given them a fourth chance. :rolleyes:
What is the difference between the "traditional cone mount" and "hub mount"? Same thing,market they? There is really only two centering designs for automotive wheels - hub centric and lug (wheel bolt) centric. The centering come on a balance machine would centre the wheel to the centre bore in the wheel, which would be the bore that the hub would also fit snug to to centre the wheel. Alternately, lug centric uses the tapered lug nuts to centre the wheel, with the wheel centre bore being larger that the axle hub.
Or you could be like GM, and have the wheel bore snug to the hub (hub centric) and use tapered lug nuts (lug centric) and see who wins the centering fight!!
Now, there are different centering cones for the Hunter balance machine. Likely they didn't have the correct one for aluminum wheels on your truck. As I recall, it's some kind of "reverse" cone arrangement. Sounds funky, and like anything else funky, can be a source of human error. Just saying......
Edited by Wrench589
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
