Just was the post from the corvette owner top of page and that is what was described to me regarding a tooth or gear that was out of acceptable tolerances. Sounds about right
When I get a chance I'll take out the drive shaft and go to a local shop here in Houston Texas and get it checked out. Hope it helps/ it's the solution for me
Here is the update on what they are seeing, he said that seven out of 10 of them tend to be fine, It tends to be more common in different configurations long beds extended cabs double cabs they think it might be related to issues with driveshaft which he said is The longest they have ever been. There is some truth to the issue being caused by tires specifically 22 inch wheel packages with Bridge stone or continentals mounted on them. They have rectified the problem in some instances by putting Michelin's on them. There was some discussion about a bulletin coming out related to the ring gear not being in specification, unacceptable variances on the teeth causing a vibration at speeds. Some of you may know this but GM will put out a bulletin ahead of a recall, if the vehicle comes in with the problem they can fix it per the bulletin but it saves them the money of doing a full recall. He feels there are secondary issues with GM putting too large and too wide of a tire on the truck that is not designed for it but that is more of his opinion. I would be curious as to how many folks with this problem have Bridgestone or continental tires, that may be the best place to start in terms of fixing it, get those tires off and have your dealer spring for Michelin's or a better tire.
GM is keeping a close eye on this but they do not want to address it in mass, and will continue to push the dealers to go with the tire balance agenda
Good luck, I think I will continue to drive my 2006 Silverado for long as I can
Thank you again daleone3! I've mentioned here before that I figured GM and their engineers knew the cause/causes of the vibration problem. I'd bet the fk'n GM bean counters have sat in smoke filled rooms several times discussing ways to avoid the issue as best they can and as long as they can. Pretty sad, especially after we bailed the SOBs out with our tax money. And jerking customers off like they have been, and will likely continue to do, will do nothing but hurt their customer base. Well, at least it sounds like they realize (hopefully) something has to be done.... bulletin will prolly happen sometime after hell freezes over LOL.
Edited by Willyone
I've read a lot of the post on here and my issue a strange vibration around 80-90mph when gunning it. I did get the balanace and rotation done and helped while cruising at 70-80mph. So while driving normal (70-80mph) no vibration at all, really smooth drive but when hitting the eccelarator and gear down shifting getting up to 90mph, I feel a vibration in the rear end which is bothering the hell out of me. It's not a huge vibration but noticeable at those speeds. Wheels are already balanced and rotated and from one person fix was getting the driveshaft checked out and balanced/ fixed.
Also I recently installed RC 2.5" leveling lift kit but I highly doubt the lift kit is causing a vibration while getting on the accelerator at 80-90mph.
I had the same issue and it ended up being my drive line angle was off, I also have a 2'' leveling kit. They put shims in the rear with the larger end facing the front of the truck and shimmed the transfer case up. What was happening was under acceleration while moving the truck that fast the engine was applying a lot of torque to the rear end which twists the rear pinion upward and makes the drive shaft angle off. Mine would only do it when i was traveling 75mph or more and accelerated hard. The joints need to cancel one another out with torque applied to them. I also have the 6.2 engine with 373 gears, so that also applies more torque to the rear end.
Edited by Silverado 6.2
I guess the one problem I have is that they are selling brand-new trucks with a problem and you are coming back and getting shims was put into the driveline that will obviously need replacement at some point will be prone to failure overtime and miles. Chevy has been doing this shit for years, I have had three Dodge trucks in the past five years and I have to tell you that the drivetrain is far more buttoned up then anything Chevy is putting on the road. I still have my 2006 Silverado with 140k and will drive that into the ground before I give them any money for a substandard product that has to be shimmed and rebalanced constantly.
I don't have a 4x4, and by shims do you mean the leveling kit shims? Or something different?
At first I was like, I'm taking the lift kit off asap but I honestly don't think the lift kit could cause that issues or I might be wrong. On the rear end it would be the bigger block under the leaf springs, and the front end just those plastic polymer and preload strut spacer in the front.
Mine does it around 80-90 accelerating hard only
Edited by Amuro
Exact same issue and setup level kit rearend and all except I have the 5.3.
My issue came back after a short while. Did yours? Also the shim kit they put in mine are silver almost like a cast something.
Is there an in vehicle road test that can be done to check for out of balance drive shaft? Taking up to 75 and dropping in Neutral and coast down... Does that stop the shaft from spinning?
No, the driveshaft is always spinning if the car is moving.
That would not stop the driveshaft from spinning as the driveshaft is solidly attached to the rear axle, so when the wheels spin, the driveshaft does as well.
Thanks, I am going to go for some exploration on the driveshaft issue balance and runout issue.
Just to recap my vibrations:
a light constant vibration in steering wheel, multiple tires, Road Force and balancing never clears it up not speed dependent
Highway speeds 65 to 85, vibration subtle 65 to 72, 73 worse, anything above 76 feels like the rear is hopping
When getting on it from 40 to 80 not much vibration, vibrations return on deceleration
Highway speed vibration seems to move from front to back and back to front when going up and down hills
Highway speed vibration seems more pronounced when going taking sweeping turns
Drive shaft will always spin like others have stated.
First thing I'll do is take out the drive shaft and get it inspected at a driveshaft shop that specialize in that type of work.
If that doesn't take care of the issue as I hope it does though, then the last step for me is to take off the RC 2.5 leveling lift kit and put the suspension back to factory and test drive it again, time consuming and redo the damn alignment again.
Funny, I was told by the dealer that I would have to pay them to balance my duratracs before they would move on to pooming at the driveshaft. I asked for a road force balance and they didnt know what that was.....
I feel that, I'm so disappointed I kinda wish I had gotten the Audi I was looking at. But I like trucks more
My exact situation, was looking at an Audi S3...pulled the trigger on the truck though. Dang!
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
