Feel sorry for ya buddy Join the crowd of us frustrated Chevy owners with the Chevy shake
That's exactly why I am here! Will report back if they have any info.
Update--Have a 2018 Silverado W/T regular cab longbed  that had the dreaded shake above 60 MPH from day one.  Did the dance with the dealership of replacing tires, vibration analysis etc. only to be told that everything was within specs, even though the vibration was still present.
     The dealership and GM Customer Care refused to buy the vehicle back or refund the purchase price so I contacted an online Lemon Law lawyer.  New Jersey lemon law rules applied in this case. The lawyer sent several letters to GM and suggested taking a cash settlement from GM and keeping the truck as opposed to going to LL court for a full refund. After 1 lowball offer from GM ended up getting a check from them that amounted to about 20% of the MSRP, they were also responsible for paying the lawyer.
       After that I ended up trading it in on a base Ford F150 and didn't end up losing anything on depreciation due to what GM paid me. Also was a night and day difference with the way the Ford rides above 60 MPH compared to the Silverado. The Chevy had under 3000 miles when I traded it in.
       I'm done with GM after this episode. The LL part took about 2 months and the lawyer said he has handled hundreds of these cases.
So do you have to go through the Customer Care issue before you start a case?  I have only commiserated with this forum but have done nothing on my side to open a case with GM.  Also I bought the truck in NM but now live in TX, would I go about contacting a TX attorney?  Sorry about your trouble but thanks for the info!
From your profile you have a 2016. In most states, note that to start a Lemon Law case you have to be the original purchaser, and you have to do it in the first year. Yours may be too late to file.
Thanks.  Man, I am the original purchaser but thought it was bent rim and never went to GM, just had them force balanced and rebalanced numerous times!  Then I got the 22" factory black rim (not sure the name) and it persisted and found this forum!
Sounds like you might be out of luck due to the time period that elapsed.  Mine did it from day one and I kept after them about it. I involved GM Customer Care because I was just following the steps in the owner's manual,talk to Service Manager,no joy talk to dealer management etc. and Customer Care was part of that progression even though from reading this particular thread and how they responded to other people on here I wasn't getting my hopes up with CC.
   Lemon Law was suggested by others on here so that ended up being the last step,they also mention it in the owner's manual.
      It's probably more difficult to get resolved if the problem doesn't show up until it's a year old or has 10000 miles on it etc. ,then they will try to blame it on any modifications that have been made
Thanks.  Yeah, that's a bummer.  I do love the truck but this gets a little tiresome to keep having it with nothing from GM if you catch it right away.
Last Friday they rebalanced all four wheels and sent me on my way. Vibration is now happening in the 60s as well. They've now had my truck for two days said they put it on the road force with no issues and was going to take the tires and wheels off another truck on the lot. I will be seeking another dealership after I get the truck back the service manager is not too friendly to say it nicely.
Sent from my Pixel 3 XL using Tapatalk
What I find interesting about this issue is that some days, I take the same road, go about 78-80 mph and have major vibration.  Other days, same road, same speed and NO vibration.  Is it possible that road heat, heat outside, etc can play a role in how much vibration there is?  The other night I had none but previously that day on the same road during the day I had the normal (what I am used to) vibration.  Just curious if mine is the only one that is intermittent.
No mine is the same way . I think some of the vibration is transmission related . Heat related for sure or Differential heat .
Strong headwind or tailwind would sometimes make a difference for me,but not necessarily every time.
They are talking about possible transmission replacement if the next test drive doesn't show any results.
did your vibration come back after the axles and driveshaft were replaced?
Brian
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
