On 6/25/2019 at 11:10 AM, Serge Messier said:
SOLVED FOR ME: I have a 2014 Silverado 5.3L LTZ and I have the stupid shake issue like so many of you. Oddly enough, I also have weird shifting like clonks which the US class action lawsuit only mentions 8 speeds when i have a 6. I road forced balanced the wheels\Tires and I have 3 sets of wheels so I know the vibration was not caused by one set. I tried tightening the leaf springs and it reduced the vibration but made the ride stiffer at lower speed.
The solution for me was adding a AFM disabler from Range technology. The vibration is gone and the transmission shifting is now smooth. It's only been one day and I am so happy, that I wanted to share.
I do love the GMC Sierra AT4 with a 10sp but don't need the 6.2L so the rumors that 2020 Sierra\Silverado 5.3L will come with the 10sp is great.
If you put it in manual shift with it set at 5 to avoid AFM did the vibrations go away or did it take the Range device to stop it?
What a bunch of bullshit There is no way that the AFM disabler from Range technology stops the vibration issues in these trucks He must be a salesman
Last time I spoke with my service writer I told him about the vibration.. At the time I had oem 22" wheels with 285/55's.  He said that they were probably causing it.  So I put my stock wheels back on and took a video at around 75mph.
Thanks for all the good posts.  Until this forum post, I thought mine was the only one that did this.  I have a friend that has a 2016 GMC SLT, 1/2 ton 5.3 (I have a 2016 4.3) and she has the same vibration issue.  I am hopeful for a resolution, this is the only issue that frustrates me on this truck!
I am not a salesman. I am an idiot like everybody else that had a vibration and have been reading these forums and watched a bunch of videos. I tried a few things with no success and found a solution that works for my truck. I did try COR's thing about driving in M5 but the vibration wasn't as bad but the transmission shifting was not pleasant.
Just like the other 832 pages of this thread, take the info you want but don't send out bad vibes you troll.
  • Like 3
I tried M5 with my '16 5.3 and it vibed.  Vibes in neutral at 70ish too.  Apparently GM fixed it in the '19 models.  So what's the big secret GM??  They won't say because they're assholes.
After we have a large enough sample size of no confirmed issues on the T1 platform with plenty of miles on the road, it would be amazing if someone out there could thoroughly document the changes to the frame/driveline/etc between the 2 and try to conclude what may have been the issue on the K2's. Other than that, we may indeed never get a definitive answer on this topic.
My oversized aluminum driveshaft did fix my vibrations along with a set of yukon axles . However i do find that the center flip up consoles are very shake prone .
I would love to know if anyone with a flow through center console has ever complained of "THE SHAKE " .
The T1 is a completely different truck from the wheels up including suspension geometry, frame, etc. So the change you want to identify is the Entire Truck.
Indeed, what I was getting at is that there is a component or components that are different that are not causing this issue on the T1 (knock on wood). If it’s the relationship of all the components on the K2 causing it, then so be it. It’s just my inquiring mind that’s curious if it can be pinpointed.
2018 Silverado with the factory 20's and continental crosscontact tires. When I first hit 75 I swear drinks will come out of the center console much worse than the video above and at 80 it actually makes me nervous. It's the first time I have had it on the interstate and have a service appointment later this week. At only 1500 miles and a month of ownership I'm not liking what I have been reading here.
2018 Silverado LT 1500, 5.3L 6SP
Edited by Raze
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
