Mine was replaced as well same type... Started moving again this week
Sent from my LG-G2
What was your vehical build date....just wondering for my own vehical if problem still exist.
Thxs
Cmillerjr could you possibly find out what the TSB number is on this new support bar fix?
bogeypro can you post your TSB number as well when you get your truck back from dealer?
My nephew has a 2014 chevy and his seat is driving him crazy. He has already had the frame replaced but movement is back. His seat is the heated/cooled/vibrating accident avoidance style.
There isn't a TSB as far as I know. It is a fix my dealer has been doing. If the part ever comes in, I'll post all the info.
Mine is not... Feels different though... Frame isn't moving feels like something loose
Sent from my LG-G2
Sent from my LG-G2
My build date is 1/14 so I guess gmc is very slow in resolving or fixing this issue.
If you want something done about it, I would report your seat movement to the NHSA as well as those crappy tires that have been causing bad vibration and all other safety related issues.
National Highway Safety Aassociation......I believe, and Ministry of Transportantion in Canada are were safety concerns can be filed for considerations.
A legal bout is our only way we will get our new vehicals fixed in the end.
Thxs
Edited by 2strokesmoke
Same here now. Before the fix it would shift on acceleration and braking
Sent from my LG-G2
17k miles on my all terrain, no seat issues. Heated but not cooled seats. 6'0 185 lbs.
Heap of other issues but seats are not one of them.
Sent from my iPad using Tapatalk HD
I thought it was the annoyance style. :lol:
I guess GM has found out that loading a seat with gizmos is not a substitute for the seat itself.
Edited by pm26
It looks like those who have problems with their seats need to go on a diet. :rolleyes:
Edited by pm26
Is it safe to assume the new Tahoe /Suburban that is rolling out have these same seats? If so maybe more complaints from those folks will get a resolution faster to movement issues.
Trackermi -- This movement issue is in nephew's truck. I would guess he is same height /weight as you.
Mine has the clunking feeling when I make turns....notified Jennifer- GM rep and will have dealer look at it next time I'm there....
service rep from my dealer called me today....said they are still waiting on parts.
This tells me that this is a very common issue. GM needs to find a fix for this and the vibration. Other than that, my truck is perfect and i wouldn't have anything else....
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
