OMG! I'm new here and I have the same complaints about my driver seat in my 2014 Z71. I've been back and forth to the dealer about it and had all the bandaids done with no resolve, in fact, it's worse than ever!
I too, wish I had my 2007 'oil consuming' truck back again. At least the seats were nice!
Hello chevy666,
We are sorry you're experiencing concerns with your seats. We'd be glad to look further into your concerns and contact your dealership. If you're interested, please send me a PM here on the site!
Andraya
GM Customer Care
Is this still happening on the 2015's?
No. They use the hose clamp fix at the factory now.:rolleyes:
Edited by pm26
I took my truck this morning to the dealer for some issues, regular maintenance, and the seat movement issue. They said they need to replace the seat tracks on mine. They ordered them and said it should be here in a week. Hopefully my seat gets fixed and it stops moving around when driving. They weren't able to fix my other issues because they said they couldn't duplicate it even though I brought in video of some of it. There's no codes so there's no issues they said. What a joke. :shakehead: I'm gonna try to post the pictures and video up here.
If GM is using the hose clamp fix they should have to pay the guy on this site for using his idea............
My 2014 Sierra SLT was delivered mid August and the drivers seat moves every time I turn a corner.
I had seat shifting movement (I hate the 2014 silverado seat!!! not made for us larger bodied people!!) dealer ordered "clips" that took a couple weeks to get in, they were replaced two days ago and so far I don't have the seat shift or noise anymore.
I had the frame replaced in my truck and it's worse than the very first time I took it in. Apparently they need to cut bolts to re attatch the new tracks to the original frame, now it comes loose because they can't duplicate the factory torque specs that were designed to never come appart in the first place. I am currently waiting for a decision from my dealer on what to do next. At this point they need to just replace the entire seat with a new one from the 2015 batch, otherwise they can just take the whole truck back!
This does not make any sense. Can't duplicate the torque spec? Every bolted connection is designed to be taken apart if needed. If you do not want something to come apart without cutting, you weld it together.
Edited by pm26
Hello chevy666,
Andraya
GM Customer Care
Andraya,
I need some help and I need a direct contact. Please email me.
Thanks
How "larger bodied"? 400+ lbs?
I waited a few months to respond on this forum, but I had seat movement also a few months ago. I told the dealer, and they ordered the necessary parts which took about 3 to 4 weeks to arrive. The seat was repaired August 2014, and since that time I have not had anymore seat movement. During my initial visit to the dealer, I did provide them a copy of the bulletin I found on this site. I guess I was lucky (so far) with the seat repair.
6'4" 290
just not near as much padding as former seats like in my 07 and 11, plus the seat is angled back so far that us with longer legs they hang off the end of the seat which is not comfortable for long trips wish I could at least bring the seat to level position instead of angled back so far.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
