I did the fix suggested here with the hose clamps however after about a few weeks it is back to moving. It isn't nearly as bad as before but still noticeable. The clamps appear to still be tight but I think I'm going to try to put another set on the outsides of the white bracket and reposition/retighten the ones on the inside to see if that helps.
Hello Guys it has been a while since I have checked in. I did not spend an hour reading all 511 posts but I wanted to let everyone know that my dealership did fix this seat shifting issue on my truck (heated and cooled leather power drivers seat) by replacing the track. Dealership is Wyatt Johnson GMC in Clarksville TN. They also replaced the leather seat cover on the bottom as the stitching was coming apart. I am officially on a diet now!!!!!!!!!!!!!
Edited by MyFavTruck
Just put the inside ones on again. Keep pressure on them when you tighten. It will work with the two.
Most report it comes back, so hopefully you can report different in a month or two.
Fixed my seat at 1,000 miles with hose clamp. Now have 11,590 miles and no seat movement. I drive over 100 miles a day and get in and out of my truck 25 plus times a day. [emoji106]
Sent from my iPhone
using Tapatalk
2 months now on the seat track replacement and all is well "no shifting" . I am at 254 so diet starts now or maybe tomorrow or next day we shall see haha.
Pounds or kilograms?
Just kidding, your seat would be no more if it was kilograms.
Edited by pm26
Your dealer appears more willing to help than mine. I just had my truck in this afternoon for the recall and asked that they check the loose seat again and I too gave them the bulletin. You can move the seat side to side by hand so I showed the service writer and he agreed it didn't seem right. Well, they said movement is normal, per the service manager, and did nothing, again. I will write a letter to the dealers owner and never buy another vehicle from them! I moved away from GM 10 years ago for quality control issues and after coming back this year I'm afraid they made little headway. Otherwise I really like the truck but this is very annoying and NOT normal. Sent from my iPad using Tapatalk
I wouldnt bother with the owner. I bought my wife a gmc terrain last year and it ended up having an intermittent discharge of the battery that the dealer couldnt find or fix, and eventualy gave up and told me to put a battery tender in. Long story short, i opened a case with a gm ambassador and gm bought it back at full price after a year.
You have to be persistent, and never give up. Never, ever, give up.
Just got my truck back and no more seat movement. My paperwork says "Performed PI1376"... does anyone know what that means? The service writer told me they installed some shims and a new clip.
m not sure on the code. What was the build date of your truck. Month and year?
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
September 2014 (9/14)
Mine is February 14. Chevy dealership tried telling me it affected early build dates like 2013. I was like whatever. Many people having problems even with 2015 models.
Sent from my iPhone
using Tapatalk
Taking mine in monday for the seat repair. The service man said they were going to install the repair kit? Let you know what happens. My dealer is usually good at fixing problems.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
