My 2019 Silverado RST Z71 in Satin Steel Metallic. I went with a 1.5” Motofab level and got some 295/60/20 Nitto Ridge Grapplers. I will get a better pic after getting it cleaned up
2019 Sierra Elevation.
Bought it as a manager’s demo.  Came with the levelling kit and slightly bigger BF Goodrich KO2’s, 275/65R20.
What kinda deal did you get on it if you don’t mind me asking?
On 10/28/2019 at 5:13 AM, TMD said:
2019 LT, Ready Lift 2" Leveling Kit, 275/70/18 Falken Wild Peaks.
I like it.....gonna do king 2.5 adj and set it at 2.5 inches with 1 inch rear block [slight rake] and keep my factory rims as you did...…..have same truck cept RST model......sucks Eibach doesn't make pro truck sport kit for 2019 afik.
Had about 10,000 km on it.  Get a full 3 year warranty the day I took it, minus the km unfortunately but not a huge deal.
It was $42,500.  That included the levelling kit that was already on it, BFG KO2’s and got them to do spray box spray liner and oil change.
It’s the Elevation trim, double cab, came with the black 20’s rims, convenience package 1 with bench seat, no center console, but has automatic climate control, heated seats and steering wheel, Max Trailering package, and integrated trailer brake controller.
I lucked out finding this truck as I was prepared to get a used 2016-18.
This is basically a new/used truck.  Saved quite a bit of cake going for this truck rather than a brand new off the lot one.
I’m very confident that this truck wasn’t abused either since it was the General Manager of the dealer’s truck, plastered with dealer stickers on the windows!
Thanks. I'm happy with the way it looks for the most part. Sometimes the truck looks perfectly level, and others it looks nose high. I might throw a 1" block in the back just for good measure. I'm happy with the tires and size - they seem to be just right w/o being obnoxious.
Please do!
I was going to try 35s but decided no too and had 295/60/20 wildpeak at3w's installed today. These are 33.9x11.7. Prob could of went bigger but they dont rub and look pretty decent.  I chose these over the 275 65s because of the width. I figured the little wider tire on the wheel would help with the stock wheels.
Edited by Flatblack83
  • Like 4
Looks stock with no level or lift, is that correct?
Yeah! More pics, please! I have the exact same truck and have been wondering what it would look like with a 1.5” and 285 or 295 tires!
This is my Trailboss, with the black parts deleted, and a 1.5” level on 285/65r20 KO2’s. Love the ride. Feels like stock.
  • Confused 1
You won't fit these tires on a stock truck without the leveling kit unless you want to trim.  It has a 2 inch readylift leveling kit up front, its a few post back with stock tires.
 I was going to add a 1 inch block to the rear and remove the stock shocks for a set of rancho 9000xl's...not sure is it worth it.
That is the same tire and tire size I want to run. Getting the 2" Ready lift level kit installed. Just waiting to see if any tire and wheel deals come up for black Friday.
Did you need to trim anything and does it rub on full lock?
Nope, doesnt rub at all plenty of room.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
