Traded in my 2019 Z71 LTZ 5.3 for this!  My 1500 really wasn't too happy towing my 8000# loaded 37' camper, lol.
This is my
2020 2500HD LTZ Z71 Gasser.  Love it!
Edited by Limelight
  • Like 6
This is my
Well that should pull it a little better, but just a little [emoji6] haha i bet it’s night and day difference!
I did the same as limelight. I bought a 2019 Sierra 1500 and was pulling a 33" travel trailer weighing about 7500lbs. The half ton wasn't handling well with that size trailer so i bought a 2500. My first HD...what a difference!b4cb92b955f91dca8d6d920c31290218.jpgbc7d23b12ee4d3ab19e0d5f896316be3.jpg
  • Like 4
Very nice!
What did you notice most/ biggest difference?  I haven’t had a chance to tow my camper with my 2500 yet...
The most notable difference is overall ride and handling. With the soft suspension of the 1500, the truck felt floaty and i was gripping the steering wheel with both hands a lot of the time. Cross winds would constantly push and pull the truck around. The second biggest difference is the gas tank. 24 gallons at 8 to 9mpg does not get you very far. With 36 gallons, i feel like i drive forever. I was also maxed out on tongue weight, payload and RGAWR.
Sent from my SM-G892A using Tapatalk
That's EXACTLY what I was hoping you would say- your experience mimics mine very closely.  I also felt a need for more power while merging and heading up grades.  Thanks for the reply, I can't wait for a test tow- hopefully next week!
Nice rides. Ditto on HD. I had a 2015 Sierra 1500 and upgraded to 2015 2500. Night and day.
Any one else’s front license plate not centered on their bumper or was my dealership just cross eyed. Just noticed it this morning. Wondering if there is a reason it offset to passenger side
4 hours ago, BB&Chiveon said:
dealer puts them on - so its probably just off
Well that’s wonderful. I haven’t looked yet but I’m assuming I have two holes in my front bumper that are off center. Pretty sad you can’t take a little more pride in your work
2020 HD Wt 4x4- 37 bfgs. Kings should be here next week, waiting on uca's
Any lift or rubbing? Power still good? That’s a lot of tire!
On 11/18/2019 at 3:47 PM, cdh7917 said:
Some new pictures of my 2500 AT4 HD, taken this evening.  The Dark Sky Metallic is such a beautiful color.
These are after a complete wash.  All Adam's Polishes products, and I can't say enough good things about their stuff.
Anyway, some subtle changes - full debadging (minus GMC badges), Red tow hooks powered black, Amp Research Powersteps, Retrax tonneau.
Hi @cdh7917 - I see you have the color matched wheel arch moldings.  When you ordered that truck, did you have to order the mud flaps separately?  On my build, I was not able to order the mud flaps separately, so wondering if the black mudflaps are part of the color match molding order code.
Also - how did you black out the marker lights in the moldings?
Thanks.
Thanks.
I bought the GMC mudflaps from a GMC dealers on eBay, separately of the purchase of the truck.  I also bought my painted fender flares from a local Chevy dealer that I had already been ordering some other parts for me.  The front mudflap for the rear wheel also fits without any issue.
There is no problem using the GMC mudflaps with the painted flares.  The painted flares are an exact match in terms of mounting/fitment to the stock black flares.
The lights - I tinted with the below product from Amazon.  It's easy to work with, especially since you'll have the lights off with the old flares and can work on them off the truck.  You'll want to use a hair dryer too, as it helps the product stretch to form.
https://www.amazon.com/gp/product/B01GQRQ996/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Edited by cdh7917
Thanks @cdh7917 - appreciate the response.
I put the painted flares on my factory order, so unfortunately I won't be able to get at the lights.  I still find it odd that they won't let you order the mud flaps when doing a factory order with painted flares.  I am glad to see that they can be added after though.
Thanks for your help.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
