21 custom, double cab, all black, gas.  Picked it up yesterday.
  • Like 4
2021 LTZ Z71 Duramax I picked up a few weeks ago.  Love it so far, just a few things that irritate me.  The auto-locking doors and 99mph limiter being a few.  Just the bed cover and steps so far but have some ideas.  Stroking that huge check put a pretty big dent in my play money!
Readylift 3/2 sst kit with fox shocks
fuel blitz 20x9 +20 offset
37x12.50 20 nitto ridge grappler
Initially it rubbed the front felt liner and mud flap in the rear. It does rub the frame rail at full lock. I removed the lower valence just because. I trimmed the mud flap and was able to bend the brackets in the front behind the felt liner enough to eliminate any rubbing.
Edited by lam0205
On 10/28/2020 at 10:59 AM, Tomato said:
Nothing is wrong with them, but the GM look better and are way more functional. One thing I do see, however, is that the GM ones do not come down like the Amp's. When I had Amps in the past, I really liked the fact that they dropped down like they do. Check out the video:
The 2021 HD step do come down. 2:27 on the video:
Why did they remove the chrome trim and leather off the shift arm? Are the same as the older ones?
I got a 2021 Chevrolet Silverado 2500 Duramax yesterday.
So far my only complaint is that they removed the adjustable pedals.  GM gives us AC/Heat in the rear seats again but takes away adjustable pedals.
Purchased today.  3500HD AT4's are hard to find and I had to drive 4 hours one way to get this girl
Edited by paulny
I'm finally back in a decent truck that doesn't ride like a brick on wheels, just traded my 18 F-350 on a 21 3500 yesterday.  Running boards, hard tonneau cover, and decent led headlight bulbs are ordered should be here by the end of the week.
2020 Brownstone Metallic 3500, Fuel Blitz 22x10...AT4.thumb.jpeg.88b4449f04a4868a9bdf23abdb07db2f.jpeg
Looks great!  What size and style tires?  Any rubbing or trimming?  Is it leveled, what kit?
Thanks! Check out this thread, has all the information on a couple size tires...
2021 Carhartt edition LTZ.   Just about everything except the Technology package.  Upgraded wheels Fuel Blitz 20" and Yokohama LT295/65/20 Geolandar M/T G003 tires.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
