Gear swap
RickLB
Looking to possible regear my 2017 GMC 1500 4x4 running 35" tires.  Currently it has 3.42 gears getting between 14 and 17.5 mpg. If I read the charts correctly, I should be running 4.10 gears to get back close to OEM settings, since 3.90 is not available for 4x4. Anyone else running 4.10s on a lifted truck?
I’m running 4.56’s with a 7” lift on 35’s. Best money I’ve spent on the truck yet.
What kind of gas mileage you getting?  What year truck and is it a 4x4? What size lift and tires are you running?
I'm very interested in this as well. I'm running a 4" lift with 35" with the factory 3.42 gears. Looking to go with 4.56 gears to help with the downshifting at the slightest hills on the highway. I got quoted $2,800 for front and rear gear swap to Yukon. Just waiting to save up the funds.
My best is 18mpg. 2017 crew cab 4x4. 7” lift 35x12.5x20 tires
Well worth the money. I paid $2250 for the swap and used Yukon gears.
Who did your gear swap?
Sent from my SM-G975U using Tapatalk
Dallas Offroad
4.56's are no doubt the best way to go. The average cost I have seen is $2500 to be done. Now, I refuse to pay that so I just did it myself and saved the $1500.
Sent from my HD1905 using Tapatalk
ordered my 4.56 gears from East Coast Gear supply, now to find someone to install them.
17 hours ago, flyingfool said:
put a locker  in it ... since your there..
Does the gear swap delete the G80 locker? Or you just mean put a REAL locker in it?
yeah I'm talking about guys with the rear peg legger.  seen so many vids on YT about locker installs on the open diff carriers on trucks , its the easiest part to install for traction. as long as you dont hit the throttle on a  hard turn they are decent mods for simple traction
there are a couple flywheel mods for the G80 gov lock, you'll have to try those at your own risk. basically it keeps the govlock locked up past 30mph,
