Add me to the list!! 2017 GMC Sierra SLT All Terrain 6.2 CCSB. This is horrible! Starts at 65mph and gets really bad at 75! At the dealer for the second time. First time they balanced the tires now I'm getting nervous! Only 800 miles on the clock!
Sorry to hear that, but you are in luck. There is a new guy who says he knows what is causing it, but he's not telling us what it is. Maybe if you feed him he will tell us, I think he likes these
2018s will be out in a few months. Just trade it in on a new 2018 and keep your fingers crossed!
No, I really do not mean it, but this problem will not be fixed as long as you people keep buying these vehicles.
So I have been following this thread for awhile now. I have a 2016 Sierra SLT AllTerrainX with the 5.3L 8-speed with just over 1500 miles. No vibration issues (knock on wood).
So just from what I have read, this seems to be the list of stuff to look for:
- balance of tires
- replacing the torque converter
- replacing or balancing the driveshaft
- checking the preload on the rear axle pinion nut (backlash?)
Edited by AllTerrainX
Yup, get a 2018, I heard on the internet they are fine lol
Would anyone be silly enough to do that ??? I bet someone will and they will be right back here when it hits 800 miles and it starts vibrating :ughdance:
Yea not looking forward to this ordeal. Started a case with GM cust service, but just got word from servicing dealer the tires were out of balance. Funny how this is the second time for a tire balance. This time they were road force balanced. I'll pick it up tomorrow and check it out.
At 800 miles on the odometer I wok not go away and I will not accept the drive it 3000 miles excuse.
Came back to a GM out of a Ford Ecoboost and NOT impressed with this chapter of GM.
Here's Ford's solution to a shaking truck-- a damper that you bolt directly to the frame. Obviously just a band aid, but I'd be happy with that at this point:
OEM 2006 Ford F-150 Frame Damper Kit Vibration 6L3Z5D008B 6L3Z-5D008-B
http://m.ebay.com/itm/191972089076?_mwBanner=1
After three trips to the local Chev dealer, the focus of which was to place the blame solely on the wheels, I took my truck to same owners larger store about 30 minutes away. My truck (2016 CCLB 6.2) vibrated from day one, but I figured it was the tires, which I swapped out after two weeks of ownership. Now I've got the aftermarket wheels, which they are placing the blame on, so I kind of screwed myself by changing out the stock wheels, and of course selling them right away (By the way, the guys at Discount Tire have been fantastic-- they've done RFB for no charge, and switched out the original Michelin LT's with P rated tires).
I asked the second dealer if they could check runout on driveshaft and wheel flanges, check pinion angle, and anything else.
Picked the truck up, they said they ran all the tests and it was within spec (providing no details what "within spec" meant, or exactly what tests they ran). The service guy wasn't in when I picked it up at 5:30, so I wasn't able to ask questions.
The service report did say they ran the Pico scope on it, and it showed a minor (within spec of course) 10Hz vibration, which is evidently first order and relates to a wheel issue (so they say). Since the wheel is attached to the axle, which is attached to the ring gear, which all rotate at the same speed, seems this vibration could be sourced from any of these components?
Since I've installed the P rated Michelins, the vibration does seem better, but it's intermittent as well, which makes it all the more frustrating.
This has been the most dismal,worthless, time-wasting customer service experience I've ever had.
At this point, I'm thinking I'm going to have to take ownership of this issue and try the leaf spring clamp fix. Evidently the Sulastic shackles don't help.
Any other ideas???
Thursday morning will be getting windshield replaced , I want to see the welds on the truck when the guy pulls the panels off
Yes, they often disassemble the entire truck to replace the windshield.
Well if I was a GM Engineer you could tell me what causes this issue and then we would both know. Have a nice day Mr Trollman.
Breakfast is on me today
Update: Picked up the truck yesterday from servicing dealership. They tell me they road force balanced the tires because selling dealership didnt do it right. I take it on the highway and vibration is immediately felt, although less violent it was still felt with the addition of a buzzing feeling in the gas pedal. I turn around and take it back, I ask if they check all the bulletins and they tell me yes. Long story short truck is back at the dealership and they are still pointing to the tires. (they did take a lot of weight) I requested Michelins if they replace the CRAPyears.
Im not convinced its tires but it is speed related and not RPM related.
Started a case with GM Cust Service but for some reason they say they have to contact Selling Dealership even though the truck is in a different state!
I sure hope that dealership isn't telling you that the wheel weights have anything to do with the Road Force measurements. If the are, then they are completely incompetent and will not be able to get the wheel/tires assemblies correct.
Road Force and mass balancing are two completely different issues and high Road Force cannot be corrected with wheel weights. If the wheel/tire has high Road Force numbers, that is caused by wheel runout, tire runout, or tire non-uniformity or any combination of the three. (Non-uniformity is variation in the stiffness of the tire tread and/or sidewall around the circumference of the tire). The only chance to correct Road Force is to re-index the wheel to the tire to cancel out Runout in the wheel and the tire. But guess what,mthatbonly works if both the wheel and the tire have some runout. If only one has,my our are SCREWED - cannot fix the Road Force variation numbers. Need to replace the offending component. And , if the hig Road Force variation numbers are caused by tire non-uniformity, you might be able to counter-act some of it with reindexing to the wheel but again, only if the wheel,has some runout. If it s true, need a new tire!
So , I think these dealers are screwing with us when they say they correctly the Road Force. I don't believe it. They are either full of crap or the technicians don't have a clue how to run the machine and are making it up smother don't look incompetent and get fired! And don't forget, GM is paying them flat rate to do this, so home much time do you think they really spend fine tuning these tires? Ha!
Lastly, after the assembly has been Road Force checked and adjusted as best as possible, a separate step is to do the traditional dynamic weight balance. That's where wheel weights get used.
I emailed the CEO of gm and received a call the next morning from the executive office. My main bitch is I received a VA auto grant worth 21k and had 12k in trade in equity. The VA grant is a one time use and I used it on a dud. I shoulda got the SS.
Edited by Kickapoo
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
