I just got a 2018 SLT All Terrain and it developed the vibration. This is my second truck, (first was repurchased). Dealer has attempted to balance tires two times and it gets worse each time. Now it’s at the dealer and they tell me the front to tires belts are broken.
I have already opened a case with GM and formally requested a different brand in tires (Michelin) due to safety concerns.
Dealer is telling me they can only install SR-A 275-55R20.
Anyone have luck getting a different brand tire installed?
On the truck that was repurchased I saw it for sale and had Bridgestones installed and was a CPO with a clean title.
My dealer replaced my sr-a at 1000 miles due to flat spots. I requested Michelin's and told them I would pay the difference between the two. It was no problem.
My fear of doing this is it absolves GM of any responsibility if the symptoms are still present.
I've had my truck for a little over a month.  I'm loving it (for the most part).  However, my truck has had some vibration at highway speeds.  I'm on vacation, and before leaving, I dropped my truck off at the dealer.  It has about 1300mi on it, and I had done a test ride with the service manager a couple weeks ago.  At that time he noted that on torque lockup it started up.  They texted me today and say that it is going to need a new torque converter!  They went to order the part and found they had one in stock.  So, hopefully upon my return, it will have been replaced and the problem resolved.  Crossing my fingers.
A "CPO" or a "CPOS"?
They can try to blame the tires, but using different tires than OEM (assuming they are same size and load rating as the OEM) in no way affects the vehicle warranty.
Today is day 50 and still not fixed and a new milestone.  I suggested the dealer try another brand of tires but GM will only replace
with same make and size as installed at the factory, in this case the GY 275x55x20's.  About 7 months ago after 5 trips to 3 different dealers and no help
I bought a complete set of 4 factory 18" wheels and tires from a 2016 Tahoe with 4500 miles on them to do my own troubleshooting.
Had them balanced and installed and lo and behold the shake was still there although some what less but at same speed and
from the rear (never had a problem from front-smooth as glass).  So evidently problem is not tires or wheels.  DUH?
Want to post a challenge...Can anyone top my 50 days continuous at a Chevrolet service department for the shake/vibrations without a fix?
To be continued....
To be continued....
Yeah....try 3 months, they did eventually buy mine back though.
WOW, 3months!  Should that be the case with myself and/or others in a buy back situation what did
GM use for the truck's value numbers?  KBB, NADA, or a mutually agreeable price?  Just want to be prepared
should that happen in my case.
Thanks in advance.
Figured I would post here in case anyone was wondering whether or not the '18 trucks had the issue or not. Bought my truck on July 27th. It's a 2018 1500 LT Z71 with 18" wheels,6 speed and 3.42 rear end. My previous truck never had the shake even running a 7 inch lift and 35's and now I have a brand new $50k truck that rides worse than my lifted truck. Drove the truck on the highway 4 days later and there was a vibration that felt like an out of balance tire. Called dealership and they said put 500 miles on it and then take it in because it could be flat spots. Figured it was probably the tires because I had been working the deal on this exact truck for over a month so it had been there for a bit. Took it in, they did a road force balance and said technician didn't feel vibrations. Picked it up and it actually feels worse so now it begins. Seriously regretting going back into a silverado after the issues on my '14 but that's my fault for not liking other trucks. Do anyways, just using this to document a bit because I'm not dealing with this by any means and I won't take it from the dealership until it is fixed. Feels like mine is milder than others have experienced but it is so annoying that I end up driving with the radio off trying to pinpoint where it's coming from. Sucks when I drive 100 miles a day on highway and cruise between 70 and 85, right where it shakes. Attached some videos below of my truck.
Thanks in advance.
Well they try to lowball you first and charge some bs mileage charge which made it worse than trade in value. Then they told me full MSRP and sent me a check that was 10 grand short of that, guess they thought I would take money and run. I got the email where they stated full MSRP and told BBB I was going to get a lawyer, 3 days later they gave me MSRP.
Edited by Chad2815
Thanks for the info Chad.  Picked up my truck yesterday (53 days) and shake still there after many new parts and tires replaced.
Now back to GM and if needed BBB.  Service manager just the middle man and did what the GM engineer told him to do.  Like to
have some time alone with that so called idiot.  Service manager would not give me the engineer's name or number.
I go by the motto...."If all else fail, let common sense prevail".
My truck is a 2015 so if a buy back happens no doubt a deduction for year and mileage be involved.  Have some numbers from
KBB and NADA for starters.  Glad to hear you ended up with a MSRP settlement.  Gives me some ammo to work with.
Note to Eric...Pursue the lemon law by contacting your state's Attorney General on your new 2018.  I found out the time limit
in my state was 18 months for the lemon law so had to go the BBB route.
I had a 2016 Silverado crew Z71 4x4 and it was smooth as glass til I was in an accident this spring when the truck had 28000 on it. To replace it I got a 2016 Sierra slt all terrain double cab and it has the shakes. Oddly enough, I have it around 42-48 mph then again at 75+. I'd be thrilled with the truck if it didn't have the slower speed shake. I never drive that fast lol. I had a PICO scope done and the dealer told me they have a truck on the lot (brand new) that shook worse. Going to take it back in and kindly ask them to check again with me on the ride so I can make sure I'm satisfied with their test. If it shakes worse I'll have them road force balance the tires and go from there to get it smoothed out.
Omg, is my truck stuck in v4 mode now, ****.n A! it sounds like I have clogged injectors. hopefully this is all it is. I find out after tomorrow my tech at Chevrolet is going to clean em as well as drain difs and trans flush. wish me luck!
Edited by Gofas
Hey gang,
   Not sure where this post will show up, but add me to the list of 2018 Silverado 4WD owners with the "Chevy Shake"...grrr. Pointed it out to the salesman while test driving. Contacted him after taking it home that the vibration was still there. I have had it back to the dealer twice now for the issue and will be in for the 3rd time tomorrow. The dealer has load balanced the wheels (20"), tried different wheels, balanced the drive shaft and sent one set of "pico" readings to Tech Support. They have spun it up on the hoist with wheels on, wheels off, suspension hanging and with vehicle on stands. Apparently, tomorrow another set of pico readings will be taken and sent to Tech Support. I haven't owned the truck for 30 days yet. Very concerned to say the least, especially after reading of all these similar complaints with very little fixes. My guess is diff or tranny. This truck has the 6spd automatic and like one post I read, seems to click through the gears way to quick.
   I live in Canada and am unsure of next steps or best direction for handling this. I have contacted the customer complaints and spoke to a representative or as they call them, ambassador to enter a case report. The dealer has been documenting through work orders and case submission to Tech Support. What do I need to do to cover my own rear-end?
Bakerman65
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
