2 hours ago, AE1M said:
Still looking for a used 2016-2017.  Is this vibration problem in every truck or is it just hit & miss?
Bob
I have several friends and family with 2014-2018s and I'm the only one that has had vibration issues.  Always test drive up to 75 mph and see if it shakes.  One that does not shake will be smooth even on loud / rough surfaces, the ones that shake will feel awful even on the best pavement.  Walk away from any that dont feel smooth as glass  because there are plenty out there that ride great.
Thank you for the reply, I went to test drive a High Country today and took it up to 80mph and it seemed very smooth.  Is this a problem that develops over time?
Mine was there from day 1, and most I've heard about were basically day 1 issues as well that just got worse over time, and/or it was missed during the test drive because they never got up to highway speed.  If you can drive 75-80 and don't feel a shake, it's probably one of the many that dont have a problem.
My 2014 had the shake from 73-80mph, it would be there some mornings and not others and then the ride home it may be there and it may not. I had Firestone Destination AT P275/55 R20 installed before i picked it up from the dealership new. I changed my tires out 2k miles ago to BFG KO2 275/55 R20 load range D and have not had the shake since. I think its something to do with the air flow/aerodynamics and the tire bounce from the P series tire excites it like a basket ball bouncing, i noticed the shake wouldnt be there if there was a side wind. This is just my evaluation over the last 4.5 years of owning it.
  • Thanks 1
My truck developed the shake at 28k miles. Was aware of the problem early on and periodically drove up to 80mph to see if the shake was there. Once it showed up, it came and went randomly.. towing a boat did not help the shakes... it also got a minor shake around 40mph.
To me, it sounds like its a gamble...and a harmonic vibration, which will change with road condition and/or tire balance and/or bad shocks and/or drive line variations...  a critically damped system should not do this... the 2014-2018 platform is not this, imho...  good luck..
On 7/28/2018 at 6:16 PM, Bart’s Silverado said:
Buy a programmer and program the converter for hyper mileage or economy. See my other posts for more info on riding smooth. I'm satisfied with my Silverado now but definitely will never buy a GM truck again. Corporate is not interested in customer satisfaction at all. If they are they can call me at 931-675-1161 and we will discuss. Bet all I hear is the wind!
Agree @Bart’s SilveradoI'll bet a reflash to a performance tune would clear up my issue.  Does anyone have experience with defending warranty coverage after reprogramming, changing out the driveshaft, tires, rims, and/or shocks?  I would think you'd be SOL if still within warranty.  That's the only thing keeping me from taking the matter into my own hands at this point.
Well I’m taking it to dealer #2 to check and see what the vibration is about, along with the steering wheel being off center as well as the transmission (clunk, downifting). Dealer said that’s kind of “normal” and it’s probably tranny fluid needing replacing. Anyway I’ll report back with their “findings” ?
I bought a lease turn in 2015 LT Silverado this January. Only 30k on the dash. Everything I wanted. I have brought it back to the dealer 5 times for shaking issues and it's given me some serious buyers remorse.
My last converstion with the head mechanic at the Chevrolet dealership was one where he leveled with me. He stated GM is well aware of the problem and that specific dealership had box trucks full of parts shipped to it along with engineers to try and fix these vibrations.
My last visit consisted of a PICO scope for vibration where my truck was considered "well under" the limit for vibration for GM standards. The mechanic told me it's nesrly
impossible to get GM to budge on any legal action. He has sat in on many of the proceedings where the customer just wasted their time and money.
Ultimately, the result of GM engineers and their parts trucks was that the frame stiffening that GM did is preventing "some" of the trucks dissipating the vibrations from normal driving.
My vibrations have been much more noticeable at speeds around 40-45 and 70-75 now. Sometimes shimmy occurs when the AFM is trying to kick in. The truck feels like it's tripping over itself with the random driveline clunks and shuddering.
The driveline clunks i can deal with as I have driven many GM s with the same sounds for over 160k. The shaking, it pisses me off because I know the dealership has backing from GM to fix the problem.
Edited by Shawn5800
At 46k going to dealer and ordering new tires which they suggest will end my shake.  This will be 3rd set including the stock SR-a’s.
You are just throwing your money away. Please see my other posts. Your problem is driveshaft related. Get rid of that long fat aluminum driveshaft. Go to a two piece shaft if yours is 2wd or a steel replacement shaft if yours is 4wd. I recommend you look up Performance Drivelines in California.
Update...Believe my last posting was May 19th or there a bouts.  Contacted BBB just before the 36/36 B-B warranty
expired, OK, they set up an arbitration hearing at their office in mid June in Las Vegas.  GM rep, arbitrator (lawyer), myself,
and an office clerk.  We all had to promise to tell the truth just like in court and all this was recorded.  It was very formal and
a structured outline was followed with statements followed by a Q and A session.  It lasted about an hour and a half.  The
arbitrator then went out and inspected the truck, recorded the VIN and mileage.  OK, one week later got a call about the arbitrator's ruling
and it directed GM to repair the truck to my satisfaction.  Then started GM calls, etc to find a dealer to correct the problem.  4 dealers
would not take it due to workload or ????  Finally found a dealer 100 miles away.  Took it to them 29 days ago and they are still
working on it.  Get updates weekly (tires, shocks, right rear axle, engine mounts, etc, etc).  Will pass along the outcome if and when.
Stay tuned!!!!
Stay tuned!!!!
It will wind up being the driveshaft. I replaced mine with a 2 piece steel driveshaft from Performance Drivelines and I have a very smooth riding 2017 Silverado LTZ. Love the truck now! Best $800 I ever spent. Hate that GM is too ignorant and too cheap to actually fix these trucks.
I just don’t know if I want to sink $800 in to a brand new truck (in my case). I’d rather take a loss and get a ram truck. It’s all about the principle with me. Either way I taking it to the dealership tomorrow where I bought it and see what they do
Did the other set of replacement tires not end the shake?  Why do you think the 3rd set will be different?  I fixed mine with a set of take-off wheels and tires from a Yukon, but my problem was the 22" wheels with the bad Bridgestone tires.
Well I thought if you put truck in neutral and shake stops it’s driveshaft?
my truck still shakes even in neutral. Haha or maybe drive shaft keeps spinning cause it’s connected to the rear axle, duh!
I even let dealer service guy pick tire.
they picked Nitto grappler stock size.
He says they had least problems with shake using these...
Edited by Gofas
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
