I am also experiencing some shaking with my 2018 Silverado I thought it needed an wheel alignment, so, i got that taken care off but didn't help.  So today I got another alignment done again.  Now it has a hard jerk when press on gas at stop light to go.  Need help any recommendation would help.
Edited by Victoria
you need a new torque converter
Might check the upper control arm frame bolts.  They loosen those to do the alignment.  If those are not torqued down properly, they can move and clunk when taking off or stopping, etc.   Since this is the last thing done just before you started experiencing this clunk, then I'd start there.
Yeh, there’s a TSB that’s been out awhile calling for three flushes with Mobil 1 Blue Stripe tranny fluid, filter change, reprogramming.  Some folks have had good luck with this.  I had it done on my 2015 8 spd, helped some but not completely.  But, your dealer will probably want to try this before changing your torque converter.  Sorry to learn the slow speed shift problem still exists.  Should’ve been corrected by your 2018.
Hello, I'm not sure if this is the right thread to post this to but ill give it a shot.
I have a 2018 silverado 5.3L with the 6-speed transmission. The truck only has about 16,000 miles on it and is still under warranty. The problem just recently started within the last few thousand miles or so but when traveling on the interstate between 78-82 mph (Yes, very specific speed) and goes into v4 mode the truck makes a constant shuddering noise (not sure what else to call it) and there is a slight vibration in the steering wheel but goes away once it goes back into v8. Its honestly not that bad but it doesn't do it at any other speeds when in v4 and can get annoying when traveling long distances on the interstate. Once back into v8 its totally fine and smooth. I know the range afm disabler fixes this and I will likely purchase this in the future but would like to see if there is a factory fix the dealer can do since the truck still is under warranty and has low miles. Id like to see if anyone else had this issue and if it was fixed by their dealer.
I have cruised at other speeds from under 75 mph and over 85 mph and it doesn't do it which I find weird as most people on here experience it at a variety of speeds.
Thanks!
Edited by Marshall_13
I have a 2019 Sierra SLE (new Gen.) with 9k miles on it.
Have the same shuddering/jerking issues with their 8 speed tranny as everybody else
Had the tranny fluid replaced and flushed... problem is still there.
Brought to service a 5th time, looks like the torque-converter is the next thing they'll be replacing.
Did you notice any change if and when you had torque converter replaced?
if someone can post up your trucks file in HPTuner format , i would love to look at the TCC schedule on the A8/A10 transmissions.
 ever since i Disable the TCC on my A6 i have zero shakes,clunks or lugging
Thanks!
shutt down your TCC in1-4th gear and you'll really enjoy the truck even more.  makes it feel like it has a higher stall converter and many other benefits
How is this done?
1 hour ago, Shu said:
How is this done?
with HPTuners. need to order an MDI2 or find a cheap used MDI1, if your not computer literate find a local tuner in your hood, if your truck is 2016 and older and just pay for the credits to access your Truck from HPt
the  2017 and newer trucks will require you unlock the TCU for $$$$1000-1800
have the tuner copy what Richard Wardell posted under his YT page on tuning out the TCC on a 6l80
I haven't thought of this, I have thought about purchasing the range technology device that plugs into the obd port but have held off. I just took it to my local dealer since the truck still has a substantial amount of warranty left on it. They said since my particular truck has the 5.3L with the 6 speed tranny it is very unlikely it is the torque converter, it is more common with the 8 speed trannys. The are going to replace the entire exhaust from engine manifold on back. They claim there is a valve/flap in the exhaust that might get stuck and cause this shudder/vibration at these speeds. Since its free I guess I don't really care but I'm definitely doubtful this will fix it. The next possible solution sounds like a fluid flush of the tranny and replacing it with something different.
THERE IS NOTHING WRONG WITH THE TORQUE CONVERTERS, the software is over cycling the TC and overheating the clutch mechagnism, overheating the transmission pump, sending metal debris thruout the system destoying the tranny all while your under warrantee, . soon as warrantee is up the damage is done. and you just buy a new truck or tranny
if you purchase the HPT MVPi2 it can fix your trans issues and you can disable the DOD, increase idle speed to 650-700 rpm, adjust your cooling fans for optimum temp control, correct the tcc issues and do many more things like shift point adjustments. cost you $400-700 for the interface with credits to tune pre-2017 truck find a used MVPi1 for $100-200 on ebay is even better deal
https://www.summitracing.com/parts/hpt-m02-000-04?rrec=true
I left the flapper installed on mine, i just bolted in the wide open position so its not blocking exhaust flow
Edited by flyingfool
I purchased 2014 Silverado last spring, 83k miles. What a journey it has been. Did not notice the vibration on test drive. Chevy Shake and 4 cylinder mode shutter. (these are two separate issues). Also rough shifting. I'd like to share what modifications and upgrades I made that worked for me after much research and trips to the dealer.
1. Road Force Balance. $0 by dealer
2. Hydrolic steering bushing $450. 1/2 price by dealer. Helped a little.
3. Custom steel drive shaft $400 installed by me (easy). This made huge difference! Chevy shake all but gone, 90%.
4. Range AFM Disabler. $175. No more 4 cylinder mode. No more shutter. No more burning oil. This is a no brainer.
5. Transmission tune up and inspection . Filter change and flush. $150. No more hard downshift. Still not crazy about the way it shifts overall but both dealers and trans specialist confirmed all normal for this truck, no issue.
Truck drives great now since all above work done last summer. Starting to like it again. I got a great deal on this truck so for me the additional expenses are still under book value.
I hope this helps anyone experiencing same issues and saves you some time.
Oh f*
Truck shaking again at 65 and over with new tires. This time alignment didn’t work and several balance attempts.
remember I had driveshaft spin and universal joint repair awhile back.
continental all terrains stock 265/65/18.
There is a recall on some Continental tires. You may want to check the list.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
