So the second Sierra we drove was worse than the first. Both driven at highway speeds and immediately noticeable. This is going to be a fun new adventure.
does that mean your not taking a replacement?
On to dealership No. 2 - third test drive in a 2015 Sierra today - result: vibration. Going to try one more and then I don't know. We have to see with GM what they want to do. But we can't afford to pay them 4k to have them buy back the vehicle.
Just curious, I wonder how much all of you that went and traded in brand new trucks, what was your loss? I had a 2014 Ram and unfortunately did not like it enough to keep. TIA!
When it was all said and done I Was out just a tad over $200 .00. And remember GM had my Silverado
for almost two months and put on over a 1,000 miles.
I got my Ram before I settled with GM, as I needed a truck. I went from a basic W/T 1 with a few goodies and
quite a few aftermarket items I could not remove because GM could not find a truck that did not vibrate.
MSRP to MSRP I ended up with a Ram Tradesman with all of the equipment as a LT Silverado for roughly
$3,800 less and ended up buying it for much less as the truck already had a 90 day floor plan on it.
Are you making note as to what tires are on the GMCs?
All 20" goodyears. They are all Sierra SLTs. On to the fourth Truck.
Interesting, Wranglers are listed as the original equipment on Silverado's but one of the things done to mine was replacing Wranglers with Eagles.
Try test driving one with 22" bridgestones.
My buddy has one with 22's and bridgestones. I'll try getting with him and take it for a test drive and see if it vibrates
Sent from my SM-N900V using Tapatalk
SLT's should all come with Goodyear wrangler SR-A. They are literally the cheapest tire you can buy in 275/55r20 that isn't some off brand Chinese manufacturer.
Edited by projectsummit
And the ones that GM buys from Goodyear are even cheaper... Apparently the OE tires are sub-standard to retail tires I've heard before from 3-4 different tire stores :dunno: . I'm having to wait over a week to get a full new set of tires from a "different supplier". They should be in tomorrow, I informed the service manager that I will not accept or sign for the truck until I'm satisfied.
I'd believe this! my SR-A's were very cheaply made, they had little rubber pieces sticking out of them all over the place as if the rubber mold used to make them wasn't tight enough. I've noticed also that the older version of the SR-A's with white side walls seemed to be much better quality.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
