9 hours ago, ShamrockShooter said:
I'm not really sure I see the point in any of the applications. All the frame has little holes an cutouts so you can spray the outside all you want to look pretty, but the inside where you can see or spray will be just as rusty as the outside was. Am I off base on that?
It is important to flush out the frame with a garden hose at least once a year to prevent accumulation of dirt and debris that can lead to rot inside the frame.
13 hours ago, ShamrockShooter said:
Wow, how many miles and what year is your truck?
2014.  Had around 30k when I took that picture
Damn mine looks the same as yours. Are you planning on doing anything? I've considered taking a wire wheel on a drill to the frame under the truck and then painting with POR-15 but I dunno if it's worth the hassle.
Do you launch a Boat ?....that looks pretty extensive
Has anybody had the thought that maybe wax dipping is the future? You cannot stop nature from creating rust, fords trying with their beer can body's, but sorry shit decays. I had the moment when I noticed surface rust on my 56k truck, but then I realized it's surface rust, I live in the salt belt, and about the only thing I can do is what I did with my 04 and religiously wash it..in the end my 04 had mild rust, but in the 13 years of life it never looked like the titanic
The wax coat frame is a grand idea, and I bet it would work just fine...GM seems to have an adhesion issue, which is a preparation problem and not an issue with the coating itself.
Steve
2012 2500hd
Had the dealer recoat it because it was still under the 3yr 36k.
No boat, the truck was driven by a salesman at the dealer before I bought it so I’m guessing it just got driven in salt and never washed.
If it was a demonstrator, they get washed multiple times a week...
Steve
2012 2500hd
yeah but how many of those car washes have undercarriage wash things as well?  So much salt and chemicals get up under the truck and can eat at things that way.
If it was the dealer I worked at, it got hand washed nearly every day.
Steve
2012 2500hd
I have a 17 sierra, just looked the other day, slight spot of rust where the jack/hoist touches the frame.  Seems anywhere the wax coating is disturbed will rust very quickly. I had a 2015 Silverado, got a Krown oil undercoating done. never had any rust for the 2 years I owned it even with winter road salt.  I plan to get my new truck done soon.
Like already stated, it helps to regularly spray off the undercarriage especially if you live in an area that uses road salt. Highly recommend getting a rust proofing spray done.  (not fluid film though as from what I have heard will melt the wax off all together)
Just bought 4 cans of Dauberts Nox-Rustemoji768.png X-121B.
My frame has very little of the wax left on it.
Truck has always been in NC.
Going to do it myself.
Just purchased a 2018 silverado 2500 hd a month ago and now noticing some surface rust on the frame in a few spots. Factory wax is not as bad as the 2013 gmc sierra 1500 I purchased new. I wanted to get the line-x undercoating but wasn't 100% sold and did not want to void the factory rust warranty, if that really matters. What would be the best course of action to stop this mild surface rust dead in its tracks?
Forget undercoating......just spray any rust areas with Rust-Oleum RUST REFORMER comes in a spray can. Instantly converts rust to a protected surface....chemically converts the iron oxide to a rustproof compound with a flat black finish matching the existing frame coating. Sprayed the few rusted frame contact areas 2 Winters ago and still good.
Is this the right stuff? Box of 6. Thanks man!
https://www.amazon.com/dp/B00M0NT53S/ref=cm_sw_r_cp_apa_GL.NAbN7N31ES
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
