sorry for all the multiposts, tapatalk kept giving me errors on my phone but was actually posting it.
With this harness, should the led inside the lid come on anytime it’s opened or only with the key in the forward position?
Edited by joer
Lid open when key in the on/running position.
Where is everyone sourcing the parts?  Especially the Console Assembly Part # 84502917.  Every online retailer I try to order from says it is on national back order with no ETA on when it's going to be available.
Thanks
I have a 2015 Silverado LT, my jump seat has the 2 usb port, jack port and the HDMI SLOT it also has the usb port on the top of the glove box... and im looking to upgrade to the full center console with the wireless charging. What would be the harness that i need? Do i need extra wire? Do you provide the wire? Also im looking to upgrade to have apple car play/android auto, what else would i need?
Thanks
This is due to Covid - GM is on a severe National Backorder status with these.  I have customers waiting almost 2 months now.
On 10/1/2020 at 8:48 PM, Waldner Brian said:
how could i order the Jump Seat to Full Center Console Retrofit
Plug and Play Harness
You can contact me at HarnessDR.com - If you have a  2016 - 2018 Truck, you can order here:
https://harnessdr.com/product/16-pin-center-console-conversion-harness/
Lead times are about 3-4 weeks at this time.  If you have a 2014 truck, you will need to remove your jump seat, extract the harness, and send it in to me.  I'll then rebuild it and send it back to you.  If you have a 2015 truck, we have to confirm which version you have.
https://harnessdr.com/product/23-pin-center-console-conversion-harness/#
Contact me at HarnessDR.com - Since you have a 2015, we need to verify which version harness you'll need.  As for carplay/android auto conversion, that's a separate upgrade process that can be done by WAMS (www.WhiteAutoandMedia.com) - Here is the link of that.  https://www.whiteautoandmedia.com/product/2014-2015-5-c-k-platform-car-play-upgrade-retrofit-programming/
Edited by pgamboa
Thanks to Phil’s harness I finally got my Center console installed thank you again Phil you are the man ???
New Body Style 2019 Silverado LT Center Console Harness
Hello,
I saw your work from a thread on this forum. I'm wondering if you can make a wiring harness for the 2019 Silverado 1500 LT so that I can convert my bench seat to the full center console? Let me know if this is something you can do.
Thanks!
That looks so good! Did you already have full weather floor matts that go over the tranny hump?
I can't wait for these to come off of backorder as my right knee is killing me while driving without a center console to rest it again.
Thanks and no I don’t have the the full weather matt that goes over the hump.
Yes,  I can't wait either.  I have everything I need (Phil harness, cables and new two piece GM floor liners) just waiting for the console.
Did you get the console from me too? I don’t have customer names/forum names linked. :). So if you did, thank you for your patience! GM is on a severe backorder status on these and we must have depleted their inventory and likely having to manufacture more. I’m sure with Covid, that is making things worse too. I’ve been checking daily with my supplier.
Hello Pgamboa.  Yes. I placed the order with you for a new console.  I hope they ship soon. Thanks.  Very good price for a brand new console with the harness.
Great! Still waiting unfortunately. I have stopped taking orders/payments until we ship all booked orders and inventory stabilizes again.
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
    • It was all part of the tiny bit of fuel savings it goes towards what was mandated by the government. Much like cylinder deactivation. That was relaxed by the recent administration. All that doesn’t help the individual buyer. But as a whole helps the manufacturer to try to reach the previous ridiculous past mileage per gallon mandate. So yes it was mandated and added cost to the vehicle.
